Can't start RepetierHost on Linux
Posted by GoingForGold
April 24, 2013 03:22AM
Hi
I have RepetierHost on my Windows PC and love it. But my main workshop-computer runs Ubuntu, and this is where Repetier should run. I installed everything as described and started the software. This worked perfectly the first time. After this, I shut down the computer and since then, I can't start the the software again. When I try to start it out of the terminal, I get
Unhandled Exception: System.ArgumentNullException: Argument cannot be null.
Parameter name: value
  at Microsoft.Win32.RegistryKey.SetValue (System.String name, System.Object value) [0x00000]
  at (wrapper remoting-invoke-with-check) Microsoft.Win32.RegistryKeyconfused smileyetValue (string,object)
  at RepetierHost.model.PrinterModel.set_Slic3rPrint (System.String value) [0x00000]
  at RepetierHost.model.PrinterModel.readPrinterSettings () [0x00000]
  at RepetierHost.model.PrinterModel..ctor () [0x00000]
  at RepetierHost.Main..ctor () [0x00000]
  at (wrapper remoting-invoke-with-check) RepetierHost.Main:.ctor ()
  at RepetierHost.Program.Main () [0x00000]
I have the newest version.
Edited 1 time(s). Last edit at 04/24/2013 03:41AM by GoingForGold.
Re: Can't start RepetierHost on Linux
April 24, 2013 06:46AM
There was a mono problem I had to work around. So make sure you have 0.85c
It might also a problem with the registry. Check your ~/.mono directory and try if renaming the host subdirectory helps starting again (also loosing all settings, but you can then rename back and check which subdirectory causes this.)
But the error is exactly in the repaired parts, so hopefully upgrading already works.
April 24, 2013 07:28AM
Unfortunately I already have the 0.85c version, I also reinstalled it now to be sure. I have the same result
I renamed the printer folder in the mono folder and now everything works again! thanks
Edit: Do you know how I could make a shortcut on the desktop?
Edited 2 time(s). Last edit at 04/24/2013 07:31AM by GoingForGold.
April 24, 2013 08:12AM
With so many linux distributions with different desktops I have no idea, especially because I'm no real linux user. I once had a desktop where each icon was a small text file with image path and program. But I'm sure if you google how to do it for your special linux/desktop combination you will find an easy tutorial.
April 24, 2013 08:16AM
Thanks, I thought there has to be an easy way grinning smiley
Unfortunately, it worked now only for a few times, now I'm as before, I have do delete the printer folder every time I want to start my repetierHost..
April 24, 2013 08:20AM
That doesn't sound right. Can you upload the defect mono directory for testing. Perhaps there is still something that needs fixing unter linux, also I had no problems and heard no problems. What Ubuntu version are you using?
May 01, 2013 07:11AM
same problem here! solved by remove printer folder in ~/.mono...
using latest version on ubuntu 10.4 EMC winking smiley , fresh installed
i have printerfolder attached
Edited 1 time(s). Last edit at 05/01/2013 07:44AM by destruktor.
open | download - printer.tar.gz (765 bytes)
September 16, 2013 11:56AM
I have found solution.
It seems that problem appears on Linux EMC (aka CNC-Linux), which is based on Ubuntu 10.04 LTS Lucid Lynx.
It is not supported any more, and hence version of Mono is quite outdated.
So, you can update Mono using instructions from
[badgerports.org]
I've now got Mono 2.10, and RepetierHost is starting normally each time.
