I just used Repetier to print out an object, no problem.
After completion, I went to print a different object.
After Adding the STL file and slicing it, the gcode editor showed the new object perfectly.
However, when I went to the "Print Panel" it showed the old object. I waited quite some time (an hour or so), it was still the same. I deleted that object and tried re-inputing the new STL/gcode. It still loads correctly up to the point of showing the gcode. Now the "Print Panel" shows NO object at all.
I am using a MAC and just downloaded the most recent version. Am I missing something somewhere???
Thank,
Drew
