Repetier, Gen7 1.5 and the heating bed May 17, 2013 08:56AM |
Re: Repetier, Gen7 1.5 and the heating bed May 17, 2013 12:49PM |
Re: Repetier, Gen7 1.5 and the heating bed May 19, 2013 12:21PM |
* Sanguino/RepRap Motherboard with direct-drive extruders
* ATMega644P
* (D 0) PB0 1| |40 PA0 (AI 0 / D31)
* (D 1) PB1 2| |39 PA1 (AI 1 / D30)
* INT2 (D 2) PB2 3| |38 PA2 (AI 2 / D29)
* PWM (D 3) PB3 4| |37 PA3 (AI 3 / D28)
* PWM (D 4) PB4 5| |36 PA4 (AI 4 / D27)
* MOSI (D 5) PB5 6| |35 PA5 (AI 5 / D26)
* MISO (D 6) PB6 7| |34 PA6 (AI 6 / D25)
* SCK (D 7) PB7 8| |33 PA7 (AI 7 / D24)
* RST 9| |32 AREF
* VCC 10| |31 GND
* GND 11| |30 AVCC
* XTAL2 12| |29 PC7 (D 23)
* XTAL1 13| |28 PC6 (D 22)
* RX0 (D 8) PD0 14| |27 PC5 (D 21) TDI
* TX0 (D 9) PD1 15| |26 PC4 (D 20) TDO
* INT0 RX1 (D 10) PD2 16| |25 PC3 (D 19) TMS
* INT1 TX1 (D 11) PD3 17| |24 PC2 (D 18) TCK
* PWM (D 12) PD4 18| |23 PC1 (D 17) SDA
* PWM (D 13) PD5 19| |22 PC0 (D 16) SCL
* PWM (D 14) PD6 20| |21 PD7 (D 15) PWM
* Gen7 1.4.1 pin assignment
#if MOTHERBOARD == 71
#define KNOWN_BOARD 1
#if !defined(__AVR_ATmega644P__) && !defined(__AVR_ATmega644__) && !defined(__AVR_ATmega1284P__)
#error Oops! Make sure you have 'Gen7' selected from the 'Tools -> Boards' menu.
#endif
//x axis pins
#define X_STEP_PIN 29
#define X_DIR_PIN 28
#define X_ENABLE_PIN 25
#define X_MIN_PIN 0
#define X_MAX_PIN -1
//y axis pins
#define Y_STEP_PIN 27
#define Y_DIR_PIN 26
#define Y_ENABLE_PIN 25
#define Y_MIN_PIN 1
#define Y_MAX_PIN -1
//z axis pins
#define Z_STEP_PIN 23
#define Z_DIR_PIN 22
#define Z_ENABLE_PIN 25
#define Z_MIN_PIN 2
#define Z_MAX_PIN -1
//extruder pins
#define E0_STEP_PIN 19
#define E0_DIR_PIN 18
#define E0_ENABLE_PIN 25
#define TEMP_0_PIN 0
#define TEMP_1_PIN 1
#define HEATER_0_PIN 4
#define HEATER_1_PIN 3
#define SDPOWER -1
#define SDSS -1
#define LED_PIN -1
#define FAN_PIN -1
#define PS_ON_PIN 15
//our pin for debugging.
#define DEBUG_PIN 0
//our RS485 pins
#define TX_ENABLE_PIN 12
#define RX_ENABLE_PIN 13
#define SDPOWER -1
#define SDSS -1
#define SDSSORIG 4 // Needs to set this to output to enable SPI even if other SS is used!
#define SCK_PIN 7
#define MISO_PIN 6
#define MOSI_PIN 5
#define E0_PINS E0_STEP_PIN,E0_DIR_PIN,E0_ENABLE_PIN,
#define E1_PINS
#endif
Re: Repetier, Gen7 1.5 and the heating bed May 19, 2013 12:28PM |
Re: Repetier, Gen7 1.5 and the heating bed May 19, 2013 01:22PM |
out.println_P(PSTR("A"));out.println(analogRead(1));
for(i=0;ienablePin > -1) {
pinMode(act->enablePin,OUTPUT);
if(!act->enableOn) digitalWrite(act->enablePin,HIGH);
out.println_P(PSTR("B"));out.println(analogRead(1));
act->tempControl.lastTemperatureUpdate = millis();
out.println_P(PSTR("C"));out.println(analogRead(1));
#ifdef SUPPORT_MAX6675
if(act->sensorType==101) {
WRITE(SCK_PIN,0);
SET_OUTPUT(SCK_PIN);
WRITE(MOSI_PIN,1);
SET_OUTPUT(MOSI_PIN);
WRITE(MISO_PIN,1);
SET_INPUT(MISO_PIN);
digitalWrite(act->tempControl.sensorPin,1);
pinMode(act->tempControl.sensorPin,OUTPUT);
#endif
out.println_P(PSTR("D"));out.println(analogRead(1));
#if HEATED_BED_HEATER_PIN>-1
out.println_P(PSTR("E"));out.println(analogRead(1));
SET_OUTPUT(HEATED_BED_HEATER_PIN);
out.println_P(PSTR("F"));out.println(analogRead(1));
initHeatedBed();
#endif
out.println_P(PSTR("G"));out.println(analogRead(1));
extruder_select(0);
#if ANALOG_INPUTS>0
ADMUX = ANALOG_REF; // refernce voltage
delay(50);
Re: Repetier, Gen7 1.5 and the heating bed May 19, 2013 02:27PM |
Re: Repetier, Gen7 1.5 and the heating bed May 21, 2013 05:32AM |
if(act->enablePin > -1) {
in the for-loop. What is that for? I don’t see any pin constants... What stands "enablePin" for?|
Re: Repetier, Gen7 1.5 and the heating bed May 21, 2013 11:59AM |
