Repetier Firmware 0.83 + Gen7 1.4 + reptier host Mac os
Posted by lolo57
May 27, 2013 12:34PM
Hello,
I'm new to the forum and I'm looking for help in problem I have with my RepRap Mendel V2.
After I finished my mechanical assembly I'm in my first!
My configuration is as follows:
Generation 7 1.4
Firmwere repetier 0.83
Host Host repetier Mac 0.56 (53)
For now x-axis and y-axis fondtionne correctly and z as well.
!! The problem is with the "panel print" of repetier host I can not do fontionner extruser and to raise temperature or extrder or the bed!!!
If someone has the same problem or the best solution thank you!
open | download - Configuration.h (47.3 KB)
open | download - pins.h (41.3 KB)
Re: Repetier Firmware 0.83 + Gen7 1.4 + reptier host Mac os
May 27, 2013 12:43PM
Supplemental information.
The M303 P0 S180 & M 303 P1 S60 works well so my hard is ok!
But the M104 to give any answer.
This
May 27, 2013 04:44PM
Two possible reasons.
1. You have dry run activated in the host. That disables extruder / heated bed.
2. Thermistor failed. Check the logs. Especially at the beginning. If you have this error you will see something about defect thermistors and enabling dry run. That happens e.g. if you have enabled the heated bed without having one.
May 28, 2013 09:51AM
I'm so Happy
You're right Dry Run is enabled on the Host!
thank you
