Testing motors on solidoodle no extruder
Posted by Smiddleton
July 25, 2013 12:50AM
Hey guys,
I'm new to the forum and to programming. I have a gen 2 solidoodle. Currently my extruder is being replaced. I was wondering if there was a way in repetier host to run the x, y, and z motors through g-code. I tried to write a simple program but I can't seem to disable the extruder so that it does it can run without it. Hope that makes sense. Any help would be very.. Well... Helpful. Thanks in advance.
SM
Re: Testing motors on solidoodle no extruder
July 25, 2013 03:27AM
1. Select Print Panel (Manual Control)
2. Click Dry Run
3. Load a G-Code file
4. Click Run
Edited 1 time(s). Last edit at 07/25/2013 10:58AM by flurin.
July 25, 2013 10:42AM
Thanks for the reply. Where is print panel? And will this work with the extruder motor unplugged? It is unplugged because the hot end is being replaced due to clogging.
July 25, 2013 10:48AM
.. Repetier Host > right top corner. I'm using Repetier-Host Mac 0.56. Which Host Version did you install?
Edit: Repetier-Host V0.90C (Windows) > Print Panel = Manual Control
Edited 5 time(s). Last edit at 07/25/2013 11:22AM by flurin.
July 25, 2013 10:59AM
I am using repetier host for windows. So it's under manual control. Okay, I will give that a try. Thanks.
July 25, 2013 11:04AM
Smiddleton Wrote:
> ... And will this work with the extruder motor unplugged?
I didn't try, but it should work without extruder (Motor and Hotend).
July 25, 2013 12:33PM
nope, it didn't work. it just makes a grinding noise after it hits the sides.
July 25, 2013 01:17PM
> replaced.
Did your printer work before you disconnected the Extruder?
Edited 1 time(s). Last edit at 07/25/2013 01:55PM by flurin.
July 25, 2013 01:24PM
Yes, it printed just fine.
July 25, 2013 01:45PM
I've just tested it with Repetier-Host Mac 0.56 without extruder and without any Temp sensors. It works for me.
After connecting the printer I clicked [Home All] first and then Run.
July 31, 2013 05:46AM
... I've just tested "Dry Run" with Marlin-Firmware, it doesn't work. You need Repetier-Firmware.
Edited 2 time(s). Last edit at 07/31/2013 05:47AM by flurin.
