Dry Run option does nothing
Posted by albert
July 30, 2013 10:24PM
I'm trying to do a dry run with Repetier and a Printrbot Jr. but when I hit "Dry Run" so that the little light turns on, it still heats up and runs just like it would otherwise.
Tried it both before and after the slicing. Also restarted the software, still the button does nothing.
Using 0.56 on a Mac. Any suggestions as to why it won't work?
Re: Dry Run option does nothing
July 31, 2013 12:05AM
Are you using Repetier firmware as well or still the stock Marlin? Dry Run mode only works on Repetier firmware, as it's actually a mode in the firmware that gets switched on, rather than filtering Gcodes on the host.
