Repetier host is not responding
Posted by edgeflyer
August 01, 2013 12:18AM
I changed my printbed settings and instead of putting a 0, I just erased the number. Repetier immediately shut down and gave me "Repetier host has stopped working". When I try to restart it I get the same eror. Trying to diagnose I found that it shows to be incompatable. It looks like it is in XP mode now and I am running windows 8.Any thoughts? Thanks
Re: Repetier host is not responding
August 01, 2013 02:57AM
Ok, I could find out how you managed that. If you make that change and click directly on ok you prevent the type check and can introduce the error causing the crash. Your main problem is, that the illegal value is now stored in registry and crashes the host on start.
Solution:
press Win+R and start regedit
Go to HKEY_CURRENT_USER\Software\repetier\printer\
You will see all values for that printer on the right one.
Change the defaultHeatedBedTemp to 0 - from your description this is the value you changed.
Now the host should start again. Next update will prevent that error and set temp to 0 on error.
August 01, 2013 02:36PM
I will try that THANK YOU !!!!!!!!!!!!!!!!!!
August 01, 2013 09:57PM
Well, I went into settings and it was set to 95. changed to 0 and it still won't run. Any other Ideas?
August 01, 2013 10:23PM
When I right click repetier host and go to compatability trouble shooter, it shows window XP. I am running windows 8. I always load windows 7-8 from solidoodle's website. Could this be an issue?
August 02, 2013 01:24AM
I would uninstall Repetier-Host, clean the registries using e.g. CCleaner and install Repetier-Host again.
August 02, 2013 03:22AM
Well you have to find the key where you made the change.
If you want to start with a clean install remove the
subtree and contents. This is the only section used by the host. A reinstall is not necessary. Removing the tree forces the host to recreate the tree with defaults.
If you are using a customized version the path differs and you should use the installer, because the customized presets are inside the installer.
August 02, 2013 03:32AM
> the
> tree with defaults.
Okay, thanks. In the past I supported Windows-Applications and I learnt, that regedit is only appropriate for advanced users. Therefore my suggestion to reinstall Repetier-Host.
August 02, 2013 04:18AM
The problem is that uninstall does not delete registry. A fact I should perhaps change, so that reinstalling really works for all users. I will see if I can ask if the user wants this in my installer.
August 03, 2013 11:45PM
How do I go about uninstalling HKEY_CURRENT_USER\Software\repetier ? I don't see where I can get to that file under the uninstall a program section.
August 04, 2013 02:58AM
It is not a file, it is a data-tree in the registry. Press
WIN+R and enter regedit. That program is the registry editor and shows it like a file system. There you can save/rename/change/delete data. But make sure you only play with that tree and not any other one. You never know what you damage in windows if you do.
August 04, 2013 03:23AM
> installer.
A workaround is to export "HKEY_CURRENT_USER\Software\Repetier" on your PC into a file and to upload this file.
This way the user would be able to douple-click this file and install the key again.
Edited 2 time(s). Last edit at 08/04/2013 04:04PM by flurin.
August 04, 2013 04:21AM
What exactly did you erase?
Obviously you did not erase the "Default Heated Bed Temperature", it was set to 95!
August 04, 2013 01:19PM
Yeah, I thought that too, but it was literally milliseconds after I hit the backspace key that I got the windows error box and it shut down.
August 04, 2013 01:34PM
So when just the main folder is highlighted and not open I cannot delete. If I highlight the sub folders I can delete those individually. Do I just go through and delete all of the folder under it individually? I cannot take a screen shot, but here is what I see. I assume I will right click and delete the folders in blue and only in blue. Also will I need to reload repetier at this point or will it regenerate correctly on its own?
HKEY_CLASSES_ROOT
HKEY_CURRENT_USER
AppEvents
Console
Control Panel
Environment
EUDC
Keyboard Layout
Network
Printers
Software
System
Volatile Environment
HKEY_LOCAL_MACHINE
HKEY_USERS
HKEY_CURRENT_CONFIG
August 04, 2013 01:38PM
NO! do not delete the blue folders!
I could check your Registry-Key if you like.
Just run regedit. Goto HKEY_CURRENT_USER > Software > Repetier
Click in Menu > File > Export to a file e.g. Repetier.reg
and upload Repetier.reg to the reprap forum.
Edited 4 time(s). Last edit at 08/04/2013 02:04PM by flurin.
August 04, 2013 02:27PM
disregard
Edited 1 time(s). Last edit at 08/04/2013 07:10PM by edgeflyer.
August 04, 2013 02:38PM
... in regedit you should goto HKEY_CURRENT_USER > Software > Repetier
- select the Repetier folder (click it)
- goto to Menu > File > Export "Repetier.reg" (approx. 6.5 KB )
Use Attach a file > Choose File > Repetier.reg
and click Attach
to upload to reprap forum.
Edited 3 time(s). Last edit at 08/04/2013 02:43PM by flurin.
August 04, 2013 03:19PM
Lets try this.
open | download - Repetier.reg (10.7 KB)
August 04, 2013 03:58PM
... the attachment is Okay. I'm analyzing your Repetier.reg.
Please delete the posting with the Registry text above in order to reduce scrolling time.
Edited 1 time(s). Last edit at 08/04/2013 04:45PM by flurin.
August 04, 2013 04:33PM
... I was searching for a value like this:
"defaultHeatedBedTemp"=""
But I didn't find any. Maybe Repetier can find the wrong value in your Repetier.reg.
I'll come back tomorrow.
Good night!
Edited 1 time(s). Last edit at 08/04/2013 04:43PM by flurin.
August 04, 2013 07:14PM
WOOOOOHOOOOOOOO. I found the Registry that had the missing value. It works now. Thank all of you for all of your help! It would be great for others to see that an uninstall and reinstall could reset all defaults though.
August 05, 2013 03:19AM
Which Registry-Value did you change?
I've found these blank entries:
"slic3rPrint"=""
"slic3rPrinter"=""
"slic3rFilament1"=""
"slic3rFilament2"=""
"slic3rFilament3"=""
"skeinforgeProfile"=""
"slic3rConfigDir"=""
"slic3rExecutable"=""
August 05, 2013 04:33PM
It was print bed default temp. I apparently looked in a different directory than before. I know that might not technically be possible, but I found one that was blank, changed it to 95 degrease and repetier loaded first try.
August 06, 2013 04:55AM
>possible
It is possible! and here is the explanation:
You've installed Repetier-Host Solidoodle V0.85b, this version has another Registry-Key:
"HKEY_CURRENT_USER\Software\RepetierSolidoodle"
Conclusion:
The Computer is merciless, the human MUST be accurate.
"Repetier host is not responding" should be "Repetier-Host Solidoodle V0.85b is not responding"
Edited 3 time(s). Last edit at 08/06/2013 05:27AM by flurin.
August 06, 2013 06:54AM
Yes, custom host versions are advised to use their own registry tree to not get into conflicts with the official host version.
August 06, 2013 09:03AM
Why didn't you post this fundamental info 5 days ago. smiling smiley
