Repetier Firmware: h-gantry + steps-per-mm September 16, 2013 08:48AM |
Re: Repetier Firmware: h-gantry + steps-per-mm September 16, 2013 04:53PM |
Re: Repetier Firmware: h-gantry + steps-per-mm September 16, 2013 06:05PM |
Re: Repetier Firmware: h-gantry + steps-per-mm September 16, 2013 07:11PM |
// maximum positions in mm - only fixed numbers! // For delta robot Z_MAX_LENGTH is maximum travel of the towers and should be set to the distance between the hotend // and the platform when the printer is at its home position. // If EEPROM is enabled these values will be overidden with the values in the EEPROM #define X_MAX_LENGTH 165 #define Y_MAX_LENGTH 175 #define Z_MAX_LENGTH 80
Re: Repetier Firmware: h-gantry + steps-per-mm September 17, 2013 06:51AM |
Re: Repetier Firmware: h-gantry + steps-per-mm September 17, 2013 07:16AM |
Re: Repetier Firmware: h-gantry + steps-per-mm September 17, 2013 02:20PM |
Re: Repetier Firmware: h-gantry + steps-per-mm September 19, 2013 09:42AM |
Re: Repetier Firmware: h-gantry + steps-per-mm September 20, 2013 12:52PM |
