repetier+eprom values
Posted by woo
woo
October 07, 2013 03:29AM
hey, just one simple question.
i am currently printing with rep. host(eprom 0), but i am switching to smart lcd, so when i change to eprom mode 1 is any way to import settings from firmware automaticaly to eeprom? there is a lot of settings, so maybe il save some time...
Re: repetier+eprom values
October 07, 2013 08:40AM
If it is the first time you enabled eeprom, it will copy all settings to eeprom. It will also do this if you change EEPROM_MODE to a new value. And after that you can always overwrite eeprom settings with the one from configuration.h with
M502
So no reason to enter them manually.
woo
October 20, 2013 11:48AM
hello, new question!
when i enable eprom mode, for example 1, then hit m502 still there are different values.
also, in host eprom editor i have options for extruder1, but i use only ext0. what am i doing wrong?
Edited 1 time(s). Last edit at 10/20/2013 11:48AM by woo.
October 20, 2013 12:16PM
Which are different? Maybe not all get copied and if I know what to look for I can correct it.
> wrong?
Nothing. Extr 1 are the settings from EXT0_ . The eeprom output simply starts counting with 1 for the extruders while configure naming matches the T0 you have to use.
woo
October 20, 2013 02:20PM
I assume i did something wrong, maybe is some parameter not changed...
also ext steps per mm dont match etc..
i noticed it when i started homing sequence, z axis waz to fast..
this is after M502
Edited 1 time(s). Last edit at 10/20/2013 02:22PM by woo.
open | download - PSREP.JPG (155.9 KB)
open | download - Configuration.h (47.3 KB)
October 21, 2013 09:04AM
Strange. Verified it in the development version and there it works as expected.
woo
October 21, 2013 04:38PM
problem partially solved! when i put in eprom mode 2 everything is fine! all values are correct. but i dont know why it doesnt work on eprom 1
