Strange heatbed thermistor behavior November 23, 2013 08:59PM |
#define NUM_EXTRUDER 2
#define MOTHERBOARD 34
#define EXT0_TEMPSENSOR_TYPE 1
// Analog input pin for reading temperatures or pin enabling SS for MAX6675
#define EXT0_TEMPSENSOR_PIN TEMP_0_PIN //<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
// WHich pin enables the heater
#define EXT0_HEATER_PIN HEATER_0_PIN //<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
#define EXT1_TEMPSENSOR_TYPE 1
#define EXT1_TEMPSENSOR_PIN TEMP_2_PIN //<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
#define EXT1_HEATER_PIN HEATER_2_PIN //<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
#define HEATED_BED_SENSOR_TYPE 1
/** Analog pin of analog sensor to read temperature of heated bed. */
#define HEATED_BED_SENSOR_PIN TEMP_1_PIN //<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
/** \brief Pin to enable heater for bed. */
#define HEATED_BED_HEATER_PIN HEATER_1_PIN //<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<
#if MOTHERBOARD == 34
#define RAMPS_V_1_3
#define AZTEEG_X3
#endif
#define KNOWN_BOARD 1
#ifdef RAMPS_V_1_3
#define HEATER_0_PIN 10
#define HEATER_1_PIN 8
#define HEATER_2_PIN 9
#define TEMP_0_PIN 13 // ANALOG NUMBERING
#define TEMP_1_PIN 14 // ANALOG NUMBERING
#define TEMP_2_PIN 15
#define E0_PINS E0_STEP_PIN,E0_DIR_PIN,E0_ENABLE_PIN,
#define E1_PINS E1_STEP_PIN,E1_DIR_PIN,E1_ENABLE_PIN,
#endif
Re: Strange heatbed thermistor behavior November 25, 2013 04:36AM |
Re: Strange heatbed thermistor behavior November 25, 2013 02:50PM |
Re: Strange heatbed thermistor behavior November 25, 2013 03:06PM |
Re: Strange heatbed thermistor behavior November 26, 2013 05:36AM |
Re: Strange heatbed thermistor behavior November 26, 2013 10:52AM |
Re: Strange heatbed thermistor behavior November 26, 2013 03:15PM |
/* read the input on sensor pins:
Therm0 - A13 (Hotend Extruder 0)
Therm1 - A14 (H-Bed)
Therm2 - A15 (Hotend Extruder 1)
Therm3 - A5 (Hotend Extruder 2)
Therm4 - A12 (Hotend Extruder 3)
int sensorValue[15];
void setup() {
// initialize serial communication at 9600 bits per second:
Serial.begin(9600);
void loop() {
sensorValue[0] = analogRead(A13);
sensorValue[1] = analogRead(A14);
sensorValue[2] = analogRead(A15);
sensorValue[3] = analogRead(A5);
sensorValue[4] = analogRead(A12);
// print out the value
for (int i=0;i<=4;i++){
Serial.print (i);
Serial.print(": ");
Serial.print(sensorValue);
Serial.print(" ");
Serial.println();
delay(500);
Re: Strange heatbed thermistor behavior November 26, 2013 04:39PM |
Re: Strange heatbed thermistor behavior November 27, 2013 10:16AM |
Re: Strange heatbed thermistor behavior November 27, 2013 01:05PM |
