heres the error after I try and add a stl file.
udoo@udoo:~$ repetierHost
udoo@udoo:~$ System.ArgumentOutOfRangeException: Argument is out of range.
Parameter name: GetItemRectangle index out of range.
at System.Windows.Forms.ListBox.GetItemRectangle (Int32 index) [0x00000] in :0
at System.Windows.Forms.ListBox.GetItemDisplayRectangle (Int32 index, Int32 first_displayble) [0x00000] in :0
at System.Windows.Forms.ListBox.InvalidateItem (Int32 index) [0x00000] in :0
at (wrapper remoting-invoke-with-check) System.Windows.Forms.ListBox:InvalidateItem (int)
at System.Windows.Forms.ListBox+SelectedIndexCollection.AddCore (Int32 index) [0x00000] in :0
at System.Windows.Forms.ListBox+SelectedIndexCollection.Add (Int32 index) [0x00000] in :0
at System.Windows.Forms.ListBox.set_SelectedIndex (Int32 value) [0x00000] in :0
at System.Windows.Forms.ListBox.set_SelectedItem (System.Object value) [0x00000] in :0
at (wrapper remoting-invoke-with-check) System.Windows.Forms.ListBox:set_SelectedItem (object)
at RepetierHost.view.STLComposer.openAndAddObject (System.String file) [0x00000] in :0
at RepetierHost.view.STLComposer.buttonAddSTL_Click (System.Object sender, System.EventArgs e) [0x00000] in :0
at System.Windows.Forms.Control.OnClick (System.EventArgs e) [0x00000] in :0
at System.Windows.Forms.Button.OnClick (System.EventArgs e) [0x00000] in :0
at System.Windows.Forms.ButtonBase.OnMouseUp (System.Windows.Forms.MouseEventArgs mevent) [0x00000] in :0
at System.Windows.Forms.Button.OnMouseUp (System.Windows.Forms.MouseEventArgs mevent) [0x00000] in :0
at System.Windows.Forms.Control.WmLButtonUp (System.Windows.Forms.Message& m) [0x00000] in :0
at System.Windows.Forms.Control.WndProc (System.Windows.Forms.Message& m) [0x00000] in :0
at System.Windows.Forms.ButtonBase.WndProc (System.Windows.Forms.Message& m) [0x00000] in :0
at System.Windows.Forms.Button.WndProc (System.Windows.Forms.Message& m) [0x00000] in :0
at System.Windows.Forms.Control+ControlWindowTarget.OnMessage (System.Windows.Forms.Message& m) [0x00000] in :0
at System.Windows.Forms.Control+ControlNativeWindow.WndProc (System.Windows.Forms.Message& m) [0x00000] in :0
at System.Windows.Forms.NativeWindow.WndProc (IntPtr hWnd, Msg msg, IntPtr wParam, IntPtr lParam) [0x00000] in :0
^C
udoo@udoo:~$ udoo@udoo:~$ repetierHost
bash: udoo@udoo:~$: command not found
udoo@udoo:~$ udoo@udoo:~$ System.ArgumentOutOfRangeException: Argument is out of range.
udoo@udoo:~$ Parameter name: GetItemRectangle index out of range.
bash: Parameter: command not found
udoo@udoo:~$ at System.Windows.Forms.ListBox.GetItemRectangle (Int32 index) [0x00000] in :0
bash: syntax error near unexpected token `('
udoo@udoo:~$ at System.Windows.Forms.ListBox.GetItemDisplayRectangle (Int32 index, Int32 first_displayble) [0x00000] in :0
udoo@udoo:~$ at System.Windows.Forms.ListBox.InvalidateItem (Int32 index) [0x00000] in :0
udoo@udoo:~$ at (wrapper remoting-invoke-with-check) System.Windows.Forms.ListBox:InvalidateItem (int)
bash: syntax error near unexpected token `wrapper'
udoo@udoo:~$ at System.Windows.Forms.ListBox+SelectedIndexCollection.AddCore (Int32 index) [0x00000] in :0
udoo@udoo:~$ at System.Windows.Forms.ListBox+SelectedIndexCollection.Add (Int32 index) [0x00000] in :0
udoo@udoo:~$ at System.Windows.Forms.ListBox.set_SelectedIndex (Int32 value) [0x00000] in :0
udoo@udoo:~$ at System.Windows.Forms.ListBox.set_SelectedItem (System.Object value) [0x00000] in :0
udoo@udoo:~$ at (wrapper remoting-invoke-with-check) System.Windows.Forms.ListBox:set_SelectedItem (object)
udoo@udoo:~$ at RepetierHost.view.STLComposer.openAndAddObject (System.String file) [0x00000] in :0
udoo@udoo:~$ at RepetierHost.view.STLComposer.buttonAddSTL_Click (System.Object sender, System.EventArgs e) [0x00000] in :0
udoo@udoo:~$ at System.Windows.Forms.Control.OnClick (System.EventArgs e) [0x00000] in :0
udoo@udoo:~$ at System.Windows.Forms.Button.OnClick (System.EventArgs e) [0x00000] in :0
udoo@udoo:~$ at System.Windows.Forms.ButtonBase.OnMouseUp (System.Windows.Forms.MouseEventArgs mevent) [0x00000] in :0
doo:~$
Edited 1 time(s). Last edit at 12/15/2013 07:44AM by firehopper.
