Repetier-Firmware Configuration Tool December 31, 2013 05:02AM |
Re: Repetier-Firmware Configuration Tool January 03, 2014 09:49PM |
Re: Repetier-Firmware Configuration Tool January 04, 2014 03:58AM |
Re: Repetier-Firmware Configuration Tool January 04, 2014 07:34AM |
Re: Repetier-Firmware Configuration Tool January 04, 2014 08:09AM |
case 60: // AD8495 (Delivers 5mV/degC vs the AD595's 10mV) currentTemperatureC = ((float)currentTemperature * 1000.0f/(1024<<(2-ANALOG_REDUCE_BITS))); break;
Re: Repetier-Firmware Configuration Tool January 04, 2014 08:52AM |
Re: Repetier-Firmware Configuration Tool January 04, 2014 01:08PM |
Re: Repetier-Firmware Configuration Tool January 04, 2014 01:16PM |
Re: Repetier-Firmware Configuration Tool January 04, 2014 01:20PM |
Re: Repetier-Firmware Configuration Tool January 04, 2014 02:14PM |
Re: Repetier-Firmware Configuration Tool January 04, 2014 04:09PM |
Re: Repetier-Firmware Configuration Tool January 04, 2014 08:52PM |
Re: Repetier-Firmware Configuration Tool January 05, 2014 02:23AM |
Re: Repetier-Firmware Configuration Tool January 05, 2014 03:13AM |
Re: Repetier-Firmware Configuration Tool January 05, 2014 04:14AM |
Re: Repetier-Firmware Configuration Tool January 05, 2014 05:36AM |
Re: Repetier-Firmware Configuration Tool January 05, 2014 05:59AM |
Re: Repetier-Firmware Configuration Tool January 05, 2014 06:48AM |
Re: Repetier-Firmware Configuration Tool January 05, 2014 07:05AM |
Re: Repetier-Firmware Configuration Tool January 05, 2014 10:09AM |
Re: Repetier-Firmware Configuration Tool January 05, 2014 10:54AM |
Re: Repetier-Firmware Configuration Tool January 05, 2014 11:04AM |
Re: Repetier-Firmware Configuration Tool January 05, 2014 11:33AM |
maralb
here it is
thanks
Re: Repetier-Firmware Configuration Tool January 05, 2014 12:06PM |
repetier
maralb
here it is
thanks
You simply had a bad timing. You started before I updated and finished after I did, so your export had invalid data for x/y/z endstop pins. Find attached the corrected version. Please reload your browser if you use the configurator again.
Re: Repetier-Firmware Configuration Tool January 18, 2014 09:25PM |
Re: Repetier-Firmware Configuration Tool January 19, 2014 08:11AM |
Re: Repetier-Firmware Configuration Tool January 19, 2014 10:28AM |
Re: Repetier-Firmware Configuration Tool January 19, 2014 10:34AM |
Re: Repetier-Firmware Configuration Tool January 19, 2014 11:04AM |
Re: Repetier-Firmware Configuration Tool January 19, 2014 11:08AM |
