host 0.95f crashing January 28, 2014 03:16PM |
Re: host 0.95f crashing January 29, 2014 12:33PM |
Re: host 0.95f crashing January 30, 2014 01:59PM |
Re: host 0.95f crashing January 31, 2014 05:19AM |
Re: host 0.95f crashing January 31, 2014 06:17AM |
Re: host 0.95f crashing January 31, 2014 12:30PM |
Re: host 0.95f crashing February 04, 2014 11:35PM |
Re: host 0.95f crashing February 05, 2014 03:05AM |
Re: host 0.95f crashing February 05, 2014 11:15AM |
Re: host 0.95f crashing February 05, 2014 04:38PM |
Re: host 0.95f crashing February 06, 2014 01:20AM |
Re: host 0.95f crashing February 06, 2014 03:27AM |
Re: host 0.95f crashing February 06, 2014 09:00AM |
Re: host 0.95f crashing February 06, 2014 09:09PM |
Re: host 0.95f crashing February 06, 2014 10:02PM |
repetier
@Scubasteve23
I could import all files within a few seconds. So it is not the file or the file handling. I also do not think it is the graphic card. Could it be a memory problem, so windows started to swap memory to disk? I used a virtual machine with 4gb ram for testing. You could try and run a performance monitor in parallel.
Re: host 0.95f crashing February 07, 2014 02:45AM |
Re: host 0.95f crashing February 07, 2014 06:06PM |
I just checked and I do have 8GB of Ram on a 64 BIt operating system... It doesnt pause at all..it just never starts...I can load anything under about 15000kb but anything more than that it goes right to (Not Responding) I don't get why it would do this...its very frustrating.... I can run solid works no problem and import these models into it in seconds if that...so I am at a loss right nowQuote
repetier
I'm a bit clueless at the moment. With 8gb memory you have more then me, so it should indeed be no memory issue. And loading is simple creation and testing of datastructures, so nothing a os can influence. Is there a special position of the progress bar where it slows down (screenshot)? Is it always with large models or are small objects (<1M also slow.
Re: host 0.95f crashing February 08, 2014 03:48AM |
Re: host 0.95f crashing February 08, 2014 01:01PM |
Re: host 0.95f crashing February 08, 2014 01:37PM |
Re: host 0.95f crashing February 08, 2014 02:17PM |
How do i verify if it is a binary stl file only? i dont have any obj format filesQuote
repetier
No I don't think the files are broken. I just thought maybe the virus scanner would prevent opening the file. In your first post you said it takes long to import them not never starts. So is it now very slow or does the progress bar never start to grow?
How about the binary stl files and obj format? Same problem there?
Re: host 0.95f crashing February 09, 2014 02:55AM |
Re: host 0.95f crashing February 10, 2014 05:29AM |
Re: host 0.95f crashing February 10, 2014 07:08AM |
Re: host 0.95f crashing March 26, 2014 02:35PM |
Re: host 0.95f crashing March 26, 2014 02:45PM |
Re: host 0.95f crashing March 26, 2014 02:48PM |
Re: host 0.95f crashing April 29, 2014 09:44PM |
Re: host 0.95f crashing June 28, 2014 05:52PM |
Re: host 0.95f crashing June 29, 2014 03:28AM |
