Manual Flow and Feed
Posted by Jomo
February 26, 2014 05:33PM
Hello
I am using Repetier Firmware and Host and slic3r.
I am new and just starting to get my first prints this week. One of the problems I am having was nozzle dragging across the print. My level and Z steps were checked and I believe are good. I reduced the Manual Flow rate and I could hear the dragging stop.
If I want to change the Manual Feed rate also, does that maintain the same ratio of extruding over distance? or does the Manual flow rate also have to bumped up as well?
If I want to update the firmware with what I learn from the manual controls, do I just multiply all the different speed parameters in slicer by the percent indicated in the manual control.
Does the Manual extruder speed control effect anything during printing?
Thanks in advance
Re: Manual Flow and Feed
February 27, 2014 06:29AM
Jomo
Hello
Feedrate adjusts flow correctly. Use flow controller only if you see too much/less extrusion.
Jomo
Exactly that is what the multiplier in Slic3r is for. Adjusting flow so 100% is correct.
Jomo
No, it is only for the manual extrusion over the interface.
February 27, 2014 07:40AM
Thanks that should set me in the right direction.
Great software you have written by the way
