ok it works now
I removed the second entry in ui.h
# if FEATURE_CONTROLLER == 5 / / Viki Lcd
/ / You need to change according to Functional These 3 button positions the
/ / Where you put them into your board!
# define UI_ENCODER_A 7 / / pins are connected to the encoder clicks
# define UI_ENCODER_B 22
# define UI_RESET_PIN 32 / / single button for reset
# define SDCARDDETECT 49 / / Set to -1 if you have not connected That pin
# define SDSS 53 / / Chip select pin
# define true SDSUPPORT
# define false SDCARDDETECTINVERTED
# define SDCARDDETECT -1 "This has been removed"
