Extruder and printbead lowering temperature upon running a job
Posted by sturm.joel
March 26, 2014 05:29PM
I have my default temperature set to 245°/100° for my extruder and printbed respectivley. Even after preheating to those temperatures it lowers them to 205°/65°, and cools too quickly to get the print started. Do I need to change values somewhere other than "Deafault" in printer settings?
Re: Extruder and printbead lowering temperature upon running a job
March 26, 2014 11:14PM
I would try reslicing your stl file, that worked for me. ( I believe it then uses your default to change gcode)
Hope this helps.
Rod
March 27, 2014 03:55AM
Normally you set temperatures in your slicer config. That overrides any temperature setting you did before. Check your filament settings in the slicer.
