Repetier for Megatronics V3.0? April 09, 2014 01:56PM |
Re: Repetier for Megatronics V3.0? April 12, 2014 04:21AM |
Re: Repetier for Megatronics V3.0? April 12, 2014 11:10AM |
Re: Repetier for Megatronics V3.0? April 12, 2014 04:51PM |
Re: Repetier for Megatronics V3.0? April 13, 2014 05:18AM |
Re: Repetier for Megatronics V3.0? April 13, 2014 12:04PM |
Re: Repetier for Megatronics V3.0? April 14, 2014 06:50PM |
Re: Repetier for Megatronics V3.0? April 15, 2014 08:58AM |
Re: Repetier for Megatronics V3.0? April 21, 2014 07:49PM |
Re: Repetier for Megatronics V3.0? April 22, 2014 02:44AM |
Re: Repetier for Megatronics V3.0? April 22, 2014 10:59AM |
Re: Repetier for Megatronics V3.0? April 22, 2014 12:01PM |
Re: Repetier for Megatronics V3.0? April 22, 2014 01:02PM |
Re: Repetier for Megatronics V3.0? April 22, 2014 07:10PM |
Re: Repetier for Megatronics V3.0? April 23, 2014 10:27AM |
Re: Repetier for Megatronics V3.0? April 23, 2014 11:02AM |
Re: Repetier for Megatronics V3.0? April 23, 2014 11:36AM |
Re: Repetier for Megatronics V3.0? April 23, 2014 07:09PM |
MrDoctorDIV
So what do I do when I want to go faster? I'm not building this printer to be slow..
Re: Repetier for Megatronics V3.0? April 23, 2014 10:02PM |
I already tried 115,200 baud and 8 bits, I don't know why I didn't notice that earlier. But I don't know what you mean by one stop bit and no parity.Quote
vreihen
Try 115,200 baud, 8 data bits, one stop bit, no parity. It is a little slow, but 100% compatible with just about everything and works on my Megatronics 2.0 board.....
Re: Repetier for Megatronics V3.0? April 23, 2014 10:24PM |
Re: Repetier for Megatronics V3.0? April 24, 2014 02:13AM |
Re: Repetier for Megatronics V3.0? April 24, 2014 08:13AM |
Re: Repetier for Megatronics V3.0? April 24, 2014 08:24AM |
Re: Repetier for Megatronics V3.0? April 24, 2014 10:36AM |
Re: Repetier for Megatronics V3.0? April 24, 2014 10:48AM |
Re: Repetier for Megatronics V3.0? April 24, 2014 10:53AM |
Re: Repetier for Megatronics V3.0? April 24, 2014 11:01AM |
Re: Repetier for Megatronics V3.0? April 24, 2014 11:06AM |
Nevermind, I should really research before asking every question.Quote
The EEPROM Trap
The trick is quite simple. The first byte in EEPROM is compared with the EEPROM_MODE value. If it has a different value, the values in your „Configuration.h“ are copied to EEPROM and byte 0 is set to the mode.
