Slic3r 1.1.1 Infill override generates hollow objects
Posted by Jef_Lord
April 29, 2014 05:20AM
Description:
When checking
   Slicer > "Override Slic3r Settings"
and modifying "Infill density" with any value, the sliced gcode will create an hollow object.
Short Analysis:
Seems Slic3r interprets "--fill-density 0.10" and round as 0 value (changes in command line parameter?)
Environment:
Repetier: 95F (Win32)
Slic3r: 1.1.1 (unstable)
Note: previous versions of Slic3r are not affected.
Reprappro Tricolour Mendel / Alpes-Maritimes [06] (FRANCE) - 06530 PEYMEINADE
Re: Slic3r 1.1.1 Infill override generates hollow objects
April 29, 2014 09:19AM
I hadn't tested it yet, but you are right. Now we need to multiply that value with 100. Would be too easy if definitions would stay the same:-) Anyway, for host release 1.0 I have added 1.1 as a version switch and selecting 1.1 - higher will fix that.
