Hi there, I have already posted this question in another forum section but I have just seen this section and figured it would be better suited here.
I have been having some trouble getting Repetier-Server installed on my Raspberry Pi (Model B Rev 2).
I have performed the following commands:
sudo apt-get install cmake
sudo apt-get install libboost-all-dev
sudo apt-get install git
I have cloned the git repository using:
git clone git://github.com/repetier/Repetier-Server.git
From there I entered the Repetier-Server using:
cd Repetier-Server
Then made the 'build' directory using:
mkdir build
Then I moved in to the 'build' directory using:
cd build
After this point is where I begin having issues. I try to run the following command:
cmake ..
It appears to work however it returns the following:
Unable to find the Boost header files. Please set BOOST_ROOT to the root directo ry containing Boost or BOOST_INCLUDEDIR to the directory containing Boost's head ers.
-- Configuring done
-- Generating done
-- Build files have been written to: /home/pi/Repetier-Server/build
I then tried to use 'make' and it returns the following:
pi@raspberrypi ~/Repetier-Server/build $ make
Scanning dependencies of target RepetierServer
[ 5%] Building CXX object CMakeFiles/RepetierServer.dir/Repetier-Server/main.cp p.o
/home/pi/Repetier-Server/Repetier-Server/main.cpp:21:37: fatal error: boost/prog ram_options.hpp: No such file or directory
compilation terminated.
make[2]: *** [CMakeFiles/RepetierServer.dir/Repetier-Server/main.cpp.o] Error 1
make[1]: *** [CMakeFiles/RepetierServer.dir/all] Error 2
make: *** [all] Error 2
I would greatly appreciate some clarification on the installation process for Repetier-Server.
Nathan
