Repetier Host Hangs on Mac OSX 10.9.3
Posted by z0rak
May 18, 2014 11:23PM
I'm having trouble getting Repetier host to start after upgrading to the latest OSX release (10.9.3). The app runs normally for a second or two and then hangs. Upgrading Repetier Host to version 0.56 (53) doesn't help. Any ideas based on the logs entres below?
5/18/14 11:09:31.944 PM Repetier-Host Mac[543]: pypy:/Applications/Repetier-Host Mac.app/Contents/Resources/pypy.app
5/18/14 11:09:33.056 PM WindowServer[109]: disable_update_timeout: UI updates were forcibly disabled by application "Repetier-Host Mac" for over 1.00 seconds. Server has re-enabled them.
5/18/14 11:09:33.513 PM WindowServer[109]: common_reenable_update: UI updates were finally reenabled by application "Repetier-Host Mac" after 1.46 seconds (server forcibly re-enabled them after 1.00 seconds)
5/18/14 11:09:33.861 PM Repetier-Host Mac[543]: *** -[__NSArrayM objectAtIndex:]: index 4294967295 beyond bounds for empty array
5/18/14 11:09:34.589 PM WindowServer[109]: disable_update_timeout: UI updates were forcibly disabled by application "Repetier-Host Mac" for over 1.00 seconds. Server has re-enabled them.
5/18/14 11:09:37.253 PM Repetier-Host Mac[543]: CGSGetWindowTransformAtPlacement
5/18/14 11:09:37.253 PM Repetier-Host Mac[543]: CGSTranslatePointForWindow
5/18/14 11:09:37.253 PM Repetier-Host Mac[543]: CGSGetWindowBounds
5/18/14 11:09:37.254 PM Repetier-Host Mac[543]: CGSTranslatePointForWindow
5/18/14 11:09:37.254 PM Repetier-Host Mac[543]: CGSGetWindowBounds
5/18/14 11:09:37.254 PM Repetier-Host Mac[543]: CGSGetWindowTransformAtPlacement
5/18/14 11:09:37.266 PM Repetier-Host Mac[543]: CGSGetWindowTransformAtPlacement
5/18/14 11:09:37.266 PM Repetier-Host Mac[543]: CGSTranslatePointForWindow
5/18/14 11:09:37.266 PM Repetier-Host Mac[543]: CGSGetWindowBounds
5/18/14 11:09:48.590 PM WindowServer[109]: disable_update_likely_unbalanced: UI updates still disabled by application "Repetier-Host Mac" after 15.00 seconds (server forcibly re-enabled them after 1.00 seconds). Likely an unbalanced disableUpdate call.
5/18/14 11:09:48.590 PM Repetier-Host Mac[543]: void CGSUpdateManager::log() const: conn 0x9d3b token 0x4ffffffffffc4c8
5/18/14 11:09:48.596 PM Repetier-Host Mac[543]: Backtrace (at 51.0216):
5/18/14 11:09:48.596 PM Repetier-Host Mac[543]: void CGSUpdateManager::log() const: 0 CoreGraphics 0x9ab5b9e7 CGSBacktraceCreate + 69
5/18/14 11:09:48.596 PM Repetier-Host Mac[543]: void CGSUpdateManager::log() const: 1 CoreGraphics 0x9ab8053d _ZN16CGSUpdateManager14disable_updateEv + 113
5/18/14 11:09:48.596 PM Repetier-Host Mac[543]: void CGSUpdateManager::log() const: 2 CoreGraphics 0x9ab80373 CGSDisableUpdateToken + 37
5/18/14 11:09:48.596 PM Repetier-Host Mac[543]: void CGSUpdateManager::log() const: 3 AppKit 0x992746a2 NSDisableScreenUpdatesToken + 46
5/18/14 11:09:48.596 PM Repetier-Host Mac[543]: void CGSUpdateManager::log() const: 4 AppKit 0x99242a69 -[NSWindow disableScreenUpdatesUntilFlush] + 142
5/18/14 11:09:48.596 PM Repetier-Host Mac[543]: void CGSUpdateManager::log() const: 5 AppKit 0x9917c672 -[NSView _updateOpenGLViewport] + 211
5/18/14 11:09:48.596 PM Repetier-Host Mac[543]: void CGSUpdateManager::log() const: 6 AppKit 0x9917c592 -[NSView(NSSurface) _updateSurfaceResolution] + 216
5/18/14 11:09:48.596 PM Repetier-Host Mac[543]: void CGSUpdateManager::log() const: 7 AppKit 0x9917c2cd _NSViewHierarchyDidChangeBackingProperties + 281
5/18/14 11:09:48.596 PM Repetier-Host Mac[543]: void CGSUpdateManager::log() const: 8 AppKit 0x99164cc4 -[NSView addSubview:] + 1514
5/18/14 11:09:48.596 PM Repetier-Host Mac[543]: void CGSUpdateManager::log() const: 9 AppKit 0x991645b1 -[NSView replaceSubview:with:] + 154
5/18/14 11:09:48.596 PM Repetier-Host Mac[543]: void CGSUpdateManager::log() const: 10 AppKit 0x9947d16c -[NSTabView _switchTabViewItemyawning smileyldView:withTabViewItem:newView:initialFirstResponder:lastKeyView:] + 803
5/18/14 11:09:48.597 PM Repetier-Host Mac[543]: void CGSUpdateManager::log() const: 11 AppKit 0x9947cac2 -[NSTabView selectTabViewItem:] + 565
5/18/14 11:09:48.597 PM Repetier-Host Mac[543]: void CGSUpdateManager::log() const: 12 AppKit 0x9947c81f -[NSTabView selectTabViewItemAtIndex:] + 64
5/18/14 11:09:48.597 PM Repetier-Host Mac[543]: void CGSUpdateManager::log() const: 13 Repetier-Host Mac 0x000067ed Repetier-Host Mac + 22509
5/18/14 11:09:48.597 PM Repetier-Host Mac[543]: void CGSUpdateManager::log() const: 14 Foundation 0x95d56732 __57-[NSNotificationCenter addObserver:selector:nameyawning smileybject:]_block_invoke + 49
5/18/14 11:09:48.597 PM Repetier-Host Mac[543]: void CGSUpdateManager::log() const: 15 CoreFoundation 0x95b655a4 __CFNOTIFICATIONCENTER_IS_CALLING_OUT_TO_AN_OBSERVER__ + 20
5/18/14 11:09:48.597 PM Repetier-Host Mac[543]: void CGSUpdateManager::log() const: 16 CoreFoundation 0x95a4705b _CFXNotificationPost + 3435
5/18/14 11:09:48.597 PM Repetier-Host Mac[543]: void CGSUpdateManager::log() const: 17 Foundation 0x95d4521f -[NSNotificationCenter postNotificationNameyawning smileybject:userInfo:] + 92
5/18/14 11:09:48.597 PM Repetier-Host Mac[543]: void CGSUpdateManager::log() const: 18 AppKit 0x99157595 -[NSApplication _postDidFinishNotification] + 367
5/18/14 11:09:48.597 PM Repetier-Host Mac[543]: void CGSUpdateManager::log() const: 19 AppKit 0x99157235 -[NSApplication _sendFinishLaunchingNotification] + 239
5/18/14 11:09:48.597 PM Repetier-Host Mac[543]: void CGSUpdateManager::log() const: 20 AppKit 0x99153b64 -[NSApplication(NSAppleEventHandling) _handleAEOpenEvent:] + 840
5/18/14 11:09:48.597 PM Repetier-Host Mac[543]: void CGSUpdateManager::log() const: 21 AppKit 0x99153451 -[NSApplication(NSAppleEventHandling) _handleCoreEvent:withReplyEvent:] + 277
5/18/14 11:09:48.597 PM Repetier-Host Mac[543]: void CGSUpdateManager::log() const: 22 libobjc.A.dylib 0x9028a304 -[NSObject performSelector:withObject:withObject:] + 77
5/18/14 11:09:48.597 PM Repetier-Host Mac[543]: void CGSUpdateManager::log() const: 23 Foundation 0x95d6547a __76-[NSAppleEventManager setEventHandler:andSelector:forEventClass:andEventID:]_block_invoke + 121
5/18/14 11:09:48.597 PM Repetier-Host Mac[543]: void CGSUpdateManager::log() const: 24 Foundation 0x95d64fb1 -[NSAppleEventManager dispatchRawAppleEvent:withRawReply:handlerRefCon:] + 430
5/18/14 11:09:48.598 PM Repetier-Host Mac[543]: void CGSUpdateManager::log() const: 25 Foundation 0x95d64dbb _NSAppleEventManagerGenericHandler + 218
5/18/14 11:09:48.598 PM Repetier-Host Mac[543]: void CGSUpdateManager::log() const: 26 AE 0x98371b15 _Z20aeDispatchAppleEventPK6AEDescPS_mPh + 387
5/18/14 11:09:48.598 PM Repetier-Host Mac[543]: void CGSUpdateManager::log() const: 27 AE 0x98340ed6 _ZL25dispatchEventAndSendReplyPK6AEDescPS_ + 44
5/18/14 11:09:48.598 PM Repetier-Host Mac[543]: void CGSUpdateManager::log() const: 28 AE 0x98340dce aeProcessAppleEvent + 318
5/18/14 11:09:48.598 PM Repetier-Host Mac[543]: void CGSUpdateManager::log() const: 29 HIToolbox 0x95442571 AEProcessAppleEvent + 55
5/18/14 11:09:48.598 PM Repetier-Host Mac[543]: void CGSUpdateManager::log() const: 30 AppKit 0x9914f168 _DPSNextEvent + 1089
5/18/14 11:09:48.598 PM Repetier-Host Mac[543]: void CGSUpdateManager::log() const: 31 AppKit 0x9914e890 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 119
5/18/14 11:10:03.204 PM Repetier-Host Mac[543]: CGSGetWindowTransformAtPlacement
5/18/14 11:10:03.204 PM Repetier-Host Mac[543]: CGSTranslatePointForWindow
5/18/14 11:10:03.204 PM Repetier-Host Mac[543]: CGSGetWindowBounds
5/18/14 11:10:03.205 PM Repetier-Host Mac[543]: CGSTranslatePointForWindow
5/18/14 11:10:03.205 PM Repetier-Host Mac[543]: CGSGetWindowBounds
5/18/14 11:10:03.205 PM Repetier-Host Mac[543]: CGSGetWindowTransformAtPlacement
5/18/14 11:10:05.274 PM Repetier-Host Mac[543]: CGSGetWindowTransformAtPlacement
5/18/14 11:10:05.274 PM Repetier-Host Mac[543]: CGSTranslatePointForWindow
5/18/14 11:10:05.274 PM Repetier-Host Mac[543]: CGSGetWindowBounds
5/18/14 11:10:05.275 PM Repetier-Host Mac[543]: CGSGetWindowTransformAtPlacement
5/18/14 11:10:05.275 PM Repetier-Host Mac[543]: CGSTranslatePointForWindow
5/18/14 11:10:05.275 PM Repetier-Host Mac[543]: CGSGetWindowBounds
5/18/14 11:10:05.463 PM Repetier-Host Mac[543]: *** -[NSLock lock]: deadlock ( '(null)')
5/18/14 11:10:05.463 PM Repetier-Host Mac[543]: *** Break on _NSLockError() to debug.
5/18/14 11:10:22.312 PM com.apple.launchd.peruser.501[175]: (repetier.Repetier-Host-Mac.45616[543]) Exited: Terminated: 15
5/18/14 11:10:48.314 PM spindump[560]: Saved hang report for Repetier-Host Mac version 0.56 (53) to /Library/Logs/DiagnosticReports/Repetier-Host Mac_2014-05-18-231048_Centauri-Prime.hang
bgm
Re: Repetier Host Hangs on Mac OSX 10.9.3
May 25, 2014 12:25AM
From a terminal window do "defaults delete repetier.Repetier-Host-Mac logSplitterHeight"
if this doesn't help do
"defaults delete repetier.Repetier-Host-Mac" it will erase all the settings for the Host.
It seems to crash when you adjust the log window size (the one at the bottom).
May 27, 2014 09:12AM
Worked for me! Thanks bgm
May 28, 2014 02:46AM
That is a good hint. I heard about that start problem and knew deleting preferences helped. Did not know that it had to do with splitter value. I also have 10.9.3 and tried to create that wrong preferences by changing the log splitter. But every change I did, did not cause any problems on restart. Does anyone of you have a hint on how to provoke the wrong value or what value gets stored that causes the crash?
