Extruder won't heat up after firmware update 0.83 tot 0.91
Posted by Sacul
May 20, 2014 11:03AM
Hello,
I have an Opiliones Large 3D-printer, using Repetier-Host 0.95F on Windows 7 Professional. It's a Delta Rostock. And I have a problem with the Repetier firmware.
After upgrading my firmware from version 0.83 (in witch the printer is working fine) tot 0.91 i can't get any heat in the extruder. Themp sensor is fine, it reads 25 degrees, and when I touch it, it heats up from the warmth of my finger. A dry run also works fine... but it just won't heat up; not by printing and not by manual control.
Going back to 0.83 fixes everything, but I wan't to work with 0.91 because, from what i've heart and read, it fixes some Delta related issues.
Anyone got any idea's? Your help would be much appreciated!
Thanks,
Lucas
Re: Extruder won't heat up after firmware update 0.83 tot 0.91
May 21, 2014 10:47AM
A wild guess is that the pins.h has changed for your board and now the output is on an other connector.
November 13, 2014 05:37PM
Send me your e-mail adress and I will sent you the 0.91 firmware
November 21, 2018 11:10AM
Hello Duckpower,
i know its a shot in the dark but i read you have the firmware for the opiliones 3D printer?
i got myself one of those printers but am all out of options for getting the firmware right. Could you send me the firmware for this printer?
Thanks in advance,
Thijs
