So you say that it is not recommended to switch those pins? The problem is that my D8 port is constantly in on-mode. It would be no problem for a fan or sth that has to run all the time anyways but for something like the heated bed where I need to control it and turn it off at an certain point this is not possible. But thanks for your advice, so I have to fix that problem with my D8 port - I think it has sth to do with the MOSFET. I try to replace it and hopefully it will get better.
EDIT: I forgot that I just need to control a relay through that port. So it shouldn't cause any problems if I use D9 for the relay (that is controlling the heated bed). The fuse should be all right. Can you tell me how to switch D8 and D9?
Edited 1 time(s). Last edit at 06/14/2014 03:18PM by LesSV.
