override Slic3r settings
Posted by serpentes
June 29, 2014 10:03AM
I'm currentliy running Repetier-Host 0.95F with Slic3r for G-Code processing. My Printer is running on Repetier-Firmware.
As long as I use my defined Slic3r Profiles everything works fine.. But if I check the "override Slic3r Settings" in Repetier Host the Printer works with the given layer thickness, but prints without infill regardless which settings i gave him..
Did anybody use this feature?
Any ideas?
Greetings
Serpentes
Re: override Slic3r settings
June 30, 2014 04:21AM
I guess you updated slic3r to 1.1.x? There you need a factor 100 for infill compared to older ones. So that only works with versin 1 of the host and if you set the right slic3r version in slicer manager.
July 02, 2014 04:21PM
you were 100% percent right.
seems to work with the repetier v1 smiling smiley
thanks for that clue
