G29 command only probing 1 location July 22, 2014 12:08PM |
// ########################################################################################## // ## Endstop configuration ## // ########################################################################################## /* By default all endstops are pulled up to HIGH. You need a pullup if you use a mechanical endstop connected with GND. Set value to false for no pullup on this endstop. */ #define ENDSTOP_PULLUP_X_MIN true #define ENDSTOP_PULLUP_Y_MIN true #define ENDSTOP_PULLUP_Z_MIN true #define ENDSTOP_PULLUP_X_MAX true #define ENDSTOP_PULLUP_Y_MAX true #define ENDSTOP_PULLUP_Z_MAX true //set to true to invert the logic of the endstops #define ENDSTOP_X_MIN_INVERTING false #define ENDSTOP_Y_MIN_INVERTING false #define ENDSTOP_Z_MIN_INVERTING false #define ENDSTOP_X_MAX_INVERTING false #define ENDSTOP_Y_MAX_INVERTING false #define ENDSTOP_Z_MAX_INVERTING false // Set the values true where you have a hardware endstop. The Pin number is taken from pins.h. #define MIN_HARDWARE_ENDSTOP_X true #define MIN_HARDWARE_ENDSTOP_Y true #define MIN_HARDWARE_ENDSTOP_Z false #define MAX_HARDWARE_ENDSTOP_X true #define MAX_HARDWARE_ENDSTOP_Y false #define MAX_HARDWARE_ENDSTOP_Z true // maximum positions in mm - only fixed numbers! // For delta robot Z_MAX_LENGTH is the maximum travel of the towers and should be set to the distance between the hotend // and the platform when the printer is at its home position. // If EEPROM is enabled these values will be overidden with the values in the EEPROM #define X_MAX_LENGTH 140 #define Y_MAX_LENGTH 90 #define Z_MAX_LENGTH 86.4 /* Z-Probing */ #define FEATURE_Z_PROBE true #define Z_PROBE_PIN ORIG_Z_MIN_PIN #define Z_PROBE_PULLUP true #define Z_PROBE_ON_HIGH true #define Z_PROBE_X_OFFSET 20.3 #define Z_PROBE_Y_OFFSET -3 #define Z_PROBE_BED_DISTANCE 5.0 // Higher than max bed level distance error in mm // Waits for a signal to start. Valid signals are probe hit and ok button. // This is needful if you have the probe trigger by hand. #define Z_PROBE_WAIT_BEFORE_TEST false /** Speed of z-axis in mm/s when probing */ #define Z_PROBE_SPEED 2 #define Z_PROBE_XY_SPEED 75 #define Z_PROBE_SWITCHING_DISTANCE 1.5 // Distance to safely switch off probe #define Z_PROBE_REPETITIONS 5 // Repetitions for probing at one point. /** The height is the difference between activated probe position and nozzle height. */ #define Z_PROBE_HEIGHT -9 /** These scripts are run before resp. after the z-probe is done. Add here code to activate/deactivate probe if needed. */ #define Z_PROBE_START_SCRIPT "M340 P0 S1500" #define Z_PROBE_FINISHED_SCRIPT "M340 P0 S600" /* Autoleveling allows it to z-probe 3 points to compute the inclination and compensates the error for the print. This feature requires a working z-probe and you should have z-endstop at the top not at the bottom. The same 3 points are used for the G29 command. */ #define FEATURE_AUTOLEVEL true #define Z_PROBE_X1 120 #define Z_PROBE_Y1 20 #define Z_PROBE_X2 120 #define Z_PROBE_Y2 70 #define Z_PROBE_X3 20 #define Z_PROBE_Y3 70
Re: G29 command only probing 1 location July 22, 2014 01:59PM |
Re: G29 command only probing 1 location July 22, 2014 03:09PM |
Re: G29 command only probing 1 location October 08, 2014 04:25PM |
Re: G29 command only probing 1 location October 09, 2014 08:45AM |
float distance = (float)sum * invAxisStepsPerMM[Z_AXIS] / (float)repeat + EEPROM::zProbeHeight();
