Y Endstop not functioning - software bug?
Posted by va3mw
August 12, 2014 12:36PM
I am running 0.91 and I have used the configurator to build my configuration.h
All axis's move in the correct direction, but I have having issues with Y hitting the endstop and not stopping. (Read on please before commenting)
Y=0 is with the carriage moved all the way to the back and at that point, it hits the endstop (and doesn't stop).
On the LCD display while watching the actual Y position, you can see that the Endstop has been sensed correctly and you can manually trigger the y=0 endstop and watch it turn on and off. This tells me that we have the pullups correctly configured, connected to the correct port on the board and the switch is working as designed. (Z and X are working correctly)
Yet, Repetier on the Ramps board does not turn off the Y motor when it validly hits the end stop and you can see it hit the endstop on the LCD readout.
This seems like a software bug, yet I am sure that many have this working.
Mike
