z axis problem
Posted by stefan787
z axis problem
August 14, 2014 10:59AM
He guys,
I finished building my 3d printer it is like a ultimake but a bit bigger.
But i have a problem, my z axis home is al the way down, so z min is home, but when it starts printing it stays down. But it have to come al the way up and when printing, slowly moves down, how do i set that up??
Thanks
Re: z axis problem
August 14, 2014 11:44AM
zmin is where your extruder touches the bed. So if your zmin is the opposite, your z direction must be inverted.
Re: z axis problem
August 14, 2014 11:58AM
ohh oke, but is it a problem that my z min endstop down is??
Re: z axis problem
August 14, 2014 12:20PM
Since down seems to be you z-max it should be the z-max endstop and then you would home to z-max and not z-min. I personally prefer the z endstop at z-max as many others do, since it makes calibrating z height easy. All you need to do is change the z length by the negative z position you see when you hit the bed.
Re: z axis problem
August 16, 2014 05:36AM
oke thaks, i fix it and my machine is up and running
