Just trying the new Repetier Host.
Two apparent bugs and a suggestion on the config for curaEngine
1. The gcode defaults editor (fourth tab, right hand side) randomly doesn't refresh properly.
It especially faults if using ctrl-Z to undo a change or ctrl-C to paste, and after doesn't refresh correctly to display the 'actual' text (this can be forced by clicking on another tab, or another text file (eg clicking from start-gcode to end-gcode and back) .
2. Following editing and saving the resultant start and end sections don't seem to replace the old ones until Repetier is closed and reloaded.
Suggestions
1. The filament tab on the same config page should be just another tab included with the other print tabs, that would get rid of one extra page, and put it in a more logical/easily noticed location.
2. Include the @ repetier codes in the help text to the left of the gcode edit tab (where the examples for {bed} etc are listed
@info message - When the host reaches this line, the text will be printed into the log file as info message.
@pause message - Pause print and display dialog box with message
@hide - hide display of following code/print actions from print preview
@show - Reenables visualization disabled by @hide.
@isathome - equivalent of G92 X0 Y0 Z0 for repetierHost (ie allows you to manually trick repetier to believer the printer has been homed)
@sound - play the file set in printer preferences
... (and any others I don't know about)
Cheers David
Edited 3 time(s). Last edit at 08/16/2014 06:07AM by dgm3333.
Setup: Prusa/Ramps 1.4 running Marlin v1.1.9 firmware. Hosted by XenialPup64 7.5 (Linux) running Repetier-host v2.1.3. Slicing: Cura. Design: OpenSCAD 2018.09.05, Blender, Inkscape. Mesh Repair: Meshlab, Netfab Basic.
