User thermistor tables in Repetier firmware August 22, 2014 10:33PM |
Re: User thermistor tables in Repetier firmware August 23, 2014 02:44AM |
#if NUM_TEMPS_USERTHERMISTOR1>0 const short temptable_6[NUM_TEMPS_USERTHERMISTOR1][2] PROGMEM = USER_THERMISTORTABLE1 ; #endif
Re: User thermistor tables in Repetier firmware March 21, 2016 08:02AM |
/* This file is optimized for version 0.92 generator: [www.repetier.com] */ #define PID_CONTROL_RANGE 20 #define SKIP_M109_IF_WITHIN 2 #define SCALE_PID_TO_MAX 0 #define TEMP_HYSTERESIS 0 #define EXTRUDE_MAXLENGTH 160 #define NUM_TEMPS_USERTHERMISTOR0 35 // 0 #define USER_THERMISTORTABLE0 {\ {51*4, 260*8},\ {52*4, 250*8},\ {62*4, 240*8},\ {76*4, 230*8},\ {81*4, 225*8},\ {92*4, 220*8},\ {97*4, 215*8},\ {116*4, 210*8},\ {119*4, 205*8},\ {134*4, 200*8},\ {140*4, 195*8},\ {128*4, 190*8},\ {177*4, 180*8},\ {215*4, 170*8},\ {247*4, 160*8},\ {335*4, 150*8},\ {407*4, 140*8},\ {461*4, 130*8},\ {550*4, 120*8},\ {665*4, 110*8},\ {724*4, 105*8},\ {820*4, 100*8},\ {1017*4, 90*8},\ {1167*4, 80*8},\ {1380*4, 70*8},\ {1638*4, 60*8},\ {1789*4, 58*8},\ {1910*4, 50*8},\ {2113*4, 45*8},\ {2191*4, 40*8},\ {2244*4, 35*8},\ {2301*4, 30*8},\ {2615*4, 27*8},\ {3124*4, 11*8},\ {3444*4, 0*8} } #define NUM_TEMPS_USERTHERMISTOR1 0 #define USER_THERMISTORTABLE1 {} #define NUM_TEMPS_USERTHERMISTOR2 0 #define USER_THERMISTORTABLE2 {} #define USE_GENERIC_THERMISTORTABLE_1 // #define GENERIC_THERM1_T0 25 // 1 #define GENERIC_THERM1_R0 20000 #define GENERIC_THERM1_BETA 3991 #define GENERIC_THERM1_MIN_TEMP -40 #define GENERIC_THERM1_MAX_TEMP 250 #define GENERIC_THERM1_R1 0 #define GENERIC_THERM1_R2 4700 #define GENERIC_THERM_VREF 5 #define GENERIC_THERM_NUM_ENTRIES 35 #define HEATER_PWM_SPEED 0
Re: User thermistor tables in Repetier firmware March 21, 2016 08:34AM |
Re: User thermistor tables in Repetier firmware March 21, 2016 09:30PM |
#define NUM_TEMPS_USERTHERMISTOR0 35 // 28 #define USER_THERMISTORTABLE0 {\ {51*4, 260*8},\ {52*4, 250*8},\ {62*4, 240*8},\ {76*4, 230*8},\ {81*4, 225*8},\ {92*4, 220*8},\ {97*4, 215*8},\ {116*4, 210*8},\ {119*4, 205*8},\ {134*4, 200*8},\ {140*4, 195*8},\ {128*4, 190*8},\ {177*4, 180*8},\ {215*4, 170*8},\ {247*4, 160*8},\ {335*4, 150*8},\ {407*4, 140*8},\ {461*4, 130*8},\ {550*4, 120*8},\ {665*4, 110*8},\ {724*4, 105*8},\ {820*4, 100*8},\ {1017*4, 90*8},\ {1167*4, 80*8},\ {1380*4, 70*8},\ {1638*4, 60*8},\ {1789*4, 58*8},\ {1910*4, 50*8},\ {2113*4, 45*8},\ {2191*4, 40*8},\ {2244*4, 35*8},\ {2301*4, 30*8},\ {2615*4, 27*8},\ {3124*4, 11*8},\ {3444*4, 0*8} }
# python 3 resistance_temperature = ( NTC-20KGJG, 20.0 kohm at 25C, B constant (25/85C) (-10.0, 5.6191), NTC-20KGJG, 20.0 kohm at 25C, B constant (25/85C) (5.0, 4.2837), (0.0, 3.2951), (5.0, 2.5563), (10.0, 1.9992), (15.0, 1.5756), (20.0, 1.2509), (25.0, 1.0), (30.0, 0.80447), (35.0, 0.65178), (40.0, 0.43523), (50.0, 0.35867), (55.0, 0.29715), (60.0, 0.24744), (65.0, 0.20705), (70.0, 0.17407), (75.0, 0.14700), (80.0, 0.12468), (85.0, 0.10619), (90.0, 0.090802), (95.0, 0.077947), (100.0, 0.067161), (105.0, 0.058076), (110.0, 0.050395), (105.0, 0.058076), (110.0, 0.050395), (115.0, 0.043876), (120.0, 0.038325), (125.0, 0.033581), (130.0, 0.029513), (135.0, 0.026015), (140.0, 0.022997), (145.0, 0.020385), (150.0, 0.018118), (155.0, 0.016145), (160.0, 0.014423), (165.0, 0.012916), (170.0, 0.011595), (175.0, 0.010432), (180.0, 0.0094078), (185.0, 0.0085024), (190.0, 0.0077006), (195.0, 0.0069890), (200.0, 0.0063559), (205.0, 0.0057917), (210.0, 0.0052878), (215.0, 0.0048367), (220.0, 0.0044323), (225.0, 0.0040690), (230.0, 0.0037421), (235.0, 0.0034473), (240.0, 0.0031811), (245.0, 0.0029403), (250.0, 0.0027220) ) for item in resistance_temperature: r = int(item[1] * 20000.0) print('{0} -> {1}'.format(item[0], r)) ''' Output -10.0 -> 112382 5.0 -> 85673 0.0 -> 65902 5.0 -> 51125 10.0 -> 39984 15.0 -> 31511 20.0 -> 25017 25.0 -> 20000 30.0 -> 16089 35.0 -> 13035 40.0 -> 8704 50.0 -> 7173 55.0 -> 5943 60.0 -> 4948 65.0 -> 4141 70.0 -> 3481 75.0 -> 2940 80.0 -> 2493 85.0 -> 2123 90.0 -> 1816 95.0 -> 1558 100.0 -> 1343 105.0 -> 1161 110.0 -> 1007 115.0 -> 877 120.0 -> 766 125.0 -> 671 130.0 -> 590 135.0 -> 520 140.0 -> 459 145.0 -> 407 150.0 -> 362 155.0 -> 322 160.0 -> 288 165.0 -> 258 170.0 -> 231 175.0 -> 208 180.0 -> 188 185.0 -> 170 190.0 -> 154 195.0 -> 139 200.0 -> 127 205.0 -> 115 210.0 -> 105 215.0 -> 96 220.0 -> 88 225.0 -> 81 230.0 -> 74 235.0 -> 68 240.0 -> 63 245.0 -> 58 250.0 -> 54 '''
#define USER_THERMISTORTABLE0 {{47,2000},{50,1960},{54,1920},{58,1880},{63,1840},{69,1800},{75,1760},{82,1720},{89,1680},{98,1640},{108,1600},{118,1560},{130,1520},{143,1480},{158,1440},{174,1400},{192,1360},{213,1320},{236,1280},{364,1120},{574,960},{910,800},{1419,640},{2100,480},{2659,320},{3316,200},{3750,40},{3931,-80}}
