Hi all
I'm in the process of moving from a GEN7 1.5 AVR (thank you Traumflug for this superb controller board) running Repetier 0.92 to a RAMPS 1.4 (that will have the same FW) in order to add an additional extruder to my Prusa i2.
The GEN7 only supports 3 endstops (min) while the RAMPS supports both min and max endstops for each axis.
I'm using 3 mechanical endstops with the GEN7 for the min of each axis but would like to use 3 additional optical endstops that I have lying around as max endstops. So my question is the following, is it possible to mix optical and mechanical endstops in the same build ? Any special configuration or thing that I have to take into account ?
Thanks for your help
Michele
