Hi!
I want to setup my new 3D-Printer with Repetier firmware, so I am using the online config tool:
www.repetier.com]
Some points are still not clear for me:
1. The PID Settings for Heater (Extruder, Bed)
What is the difference between "Max PWM value" and "PID drive maximum"?
And does the "Heater PWM speed" affect theese values? (Do I need to set "Max PWM value" to 64, when using "61Hz 64 values"?)
2. The Endstops:
What is the difference between the settings "Switch on GND" and "Electronic"?
I want to use Hall-Endstops. They have a NPN on "signal line", so they work like "common mechanical switches" (with higher impedance).
