Repetier Host on ODROID-U3?
Posted by MattSmoker17
September 17, 2014 12:20PM
Hi guys,
I'm looking for a very low-cost pc solution for running Repetier and Slic3r, Mono and Arduino IDE (under lubuntu) and I'm planning to buy an ODROID-U3 to interact with my handmade delta printer. Could you please give me any tip? has the Odroid enough power?
These are the specifications:
CPU 1.7GHz Exynos4412 Prime Cortex-A9 Quad-core processor
with PoP (Package on Package) 2Gbyte LPDDR2 880Mega Data Rate
PMIC MAX77686 Power Management IC from MAXIM
HSIC USB 2.0 Hub USB3503A Integrated USB 2.0-compatible hub / HSIC upstream port from SMSC/Microchip
HSIC Ethernet controller LAN9730HSIC USB 2.0 to 10/100 Ethernet controller with HP Auto-MDIX from SMSC/Microchip
Audio CODEC MAX98090 is a full-featured and high performance audio CODEC from MAXIM
Protection IC NCP372 Over-voltage, Over-current, Reverse-voltage protection IC from OnSemi.
USB Load switch NCP380 Protection IC for USB power supply from OnSemi.
HDMI conditioner IP4791CZ12 HDMI transmitter interface protector with level shifter from NXP
HDMI connector Standard Micro-HDMI, supports up to 1920 x 1080 resolution
Connectivity
USB Host x 3, Device x 1, Ethernet RJ-45, Headphone Jack
IO Ports
GPIO, UART, I2C, SPI(Board Revision 0.5 or higher)
Storage Slot Micro-SD slot, eMMC module connector
DC Input 5V / 2A input, Plug specification is inner diameter 0.8mm and outer diameter 2.5mm
Thanks smiling smiley
Re: Repetier Host on ODROID-U3?
October 13, 2014 07:56AM
Nobody?
October 28, 2014 01:36PM
Hi Matt,
yes, it can be work...
I Think with Slic3r ... but with Cura-engine it can be Work.
Please try for the Quad-core processor one of this OS:
[www.armhf.com]
or I think that the easierest way can be a finished EMMc Modul:
[www.pollin.de]
Important is, that the OS-Kernel support the GPU !
And Try then to Install Repetier + Cura and Slic3r etc..
Have Fun
Angelo
RADDS-Shield -> Commercial [max3dshop.org]
