Here is a bug in Repetier Host 1.0.4. With the default Cura settings, the CuraEngine CLI fails to parse the cura.ini file. See the log:
00:45:21.570 : CuraEngine command:C:\Program Files\Repetier-Host\plugins\CuraEngine\CuraEngine.exe -p -v -c "C:\Users\oscahie\AppData\Local\RepetierHost\cura.ini" -s posx=0 -s posy=0 -o "C:\Users\oscahie\AppData\Local\RepetierHost\composition.gcode" "C:\Users\oscahie\AppData\Local\RepetierHost\composition0.stl"
00:45:21.586 : Cura_SteamEngine version 14.06
00:45:21.586 : Copyright (C) 2014 David Braam
[...license...]
00:45:21.587 : Default config 'default.cfg' not used
00:45:21.587 : Config(C:\Users\oscahie\AppData\Local\RepetierHost\cura.ini): Line 80: No key value pair found
00:45:21.587 : Failed to read config 'C:\Users\oscahie\AppData\Local\RepetierHost\cura.ini'
00:45:21.587 : Loading C:\Users\oscahie\AppData\Local\RepetierHost\composition0.stl from disk...
00:45:21.587 : Loaded from disk in -0.000s
00:45:21.587 : Analyzing and optimizing model...
RH does not show any error or warning and the slicing appears to finish successfully. However the values in the resulting gcode do not match whatever I've selected in the Cura settings UI. The speed value for instance matches Cura's default 30 mm/s.
The workaround seems to be adding a comment line (eg: ";nothing") to the 'Before extruder switch' and 'After extruder switch' custom gcodes.
Edited 1 time(s). Last edit at 09/22/2014 07:16PM by oscahie.
