In earlier releases i think that z max size (printer height) in printer settings was overruling settings in firmware so if you changed printer settings you could trim printer z max height from RH. Is that wrong remembered?.
At least it does not seem to work in that way anymore.
if i change z-max size I have to upload new firmware settings. Printer settings editing does show up in control pane when homingl, but size used is the one from Firmware as least as I have experienced.
This was experienced with RH 1.05 and marlin FW. W7/X64.
