Object does not show in Host
Posted by Replace
October 18, 2014 03:36PM
I was used to Ponterface and I liked the toolhead path simulation on the screen, while printing.
Now I have moved to Repetier Host, but probably I make some errors, because:
I do not see the objects I load.
I do not se the layers when printing.
It concerns objects that have been sliced outside of Repetier (by Slic3r) so I load Gcode only.
Any idea why I do not see my objects on the build plate in the left pane ? Also not when hitting the preview tab
Thomas
www.3daybreaker.blogspot.com
Orca V4.4 rebuild to Ramps with Mk8 and E3D, as well as a Rostock Delta Mini and an OLO in backorder :-)
Re: Object does not show in Host
October 19, 2014 06:34AM
You might have "Show Filament" disabled in the top toolbar.
October 19, 2014 09:50AM
Ha.. that is for one !
So I activated the show filament button.
Now, depending on the settings of the preview screen, I see either one layer or all layers (complete object),
but I do not see the layer being built in real time, as Pronterface does,
Also it does not advance layers while the Z-table moves...
Is that not an option ?
October 19, 2014 10:52AM
You see progress only when manual control tab is active. Then you see in red what just gets printed and the rest in your filament color.
October 19, 2014 11:24AM
Than I must have an error.
On manual control, I only see 3/4 of the skirt and nothing else.
October 19, 2014 12:09PM
Check the log ()easy mode off, toggle log). It will stop updating graphics if framerate gets too low to protect print. This can happen when your pc does not use VBOs because you said so or you have a very old graphic driver.
October 19, 2014 01:52PM
I get this error in the log now:
(translated in English by myself)
Can't find entry point GlGenbuffer in OpenGL ...
So my installation is in error ?
Edited 1 time(s). Last edit at 10/19/2014 01:52PM by Replace.
October 19, 2014 02:02PM
GlGenbuffer is a function that your OpenGL driver should provide. Sounds like it does not so you should try to find a newer version and update that. I guess it is quite old? Function should be included at least since OpenGL 1.5.
October 20, 2014 03:14AM
I don't recall to have OpenGL installed actually. Does it come with Repetier ?
I Upgrade Repetier every time, just recently too.
October 20, 2014 04:04AM
No, OpenGL is part of your graphic card driver and has nothing to do with repetier except that repetier uses it for 3d visualization.
October 21, 2014 02:37AM
Ok thanks, I will investigate :-)
