First the host shows absolute positions, so G92 should not change coordinates.
Red coordinates means no homing occured so value may be incorrect. This also allows to go below z=0 which is prevented when coordinates are known.
If you are at home and firmware things the same you can send @isathome and host will set itself to origin.
You can use one of the 5 script buttons to add the command to it.
M114 updates the coordinates as well from printer (not G114). Just not sure what it does with G92 gotten so far.
Visit us on
Facebook and
Twitter!
