Repetier with SSD1306 oled display 128x64 ? May 11, 2015 08:15PM |
-=Delta G2K=-|
Re: Repetier with SSD1306 oled display 128x64 ? May 12, 2015 12:19PM |
Re: Repetier with SSD1306 oled display 128x64 ? May 12, 2015 01:12PM |
-=Delta G2K=-|
Re: Repetier with SSD1306 oled display 128x64 ? May 12, 2015 04:02PM |
-=Delta G2K=-|
Re: Repetier with SSD1306 oled display 128x64 ? May 13, 2015 03:21AM |
Re: Repetier with SSD1306 oled display 128x64 ? May 13, 2015 06:57AM |
-=Delta G2K=-|
Re: Repetier with SSD1306 oled display 128x64 ? May 13, 2015 10:49AM |
-=Delta G2K=-|
Re: Repetier with SSD1306 oled display 128x64 ? May 13, 2015 02:38PM |
-=Delta G2K=-|
Re: Repetier with SSD1306 oled display 128x64 ? May 16, 2015 04:30AM |
#define U8GLIB_SSD1306_I2C
Re: Repetier with SSD1306 oled display 128x64 ? May 16, 2015 06:43AM |
you are the best !
-=Delta G2K=-|
Re: Repetier with SSD1306 oled display 128x64 ? May 16, 2015 08:25AM |
YOU HAD THE WRONG DISPLAY !!!
-=Delta G2K=-|
Re: Repetier with SSD1306 oled display 128x64 ? May 16, 2015 09:13AM |
-=Delta G2K=-|
Re: Repetier with SSD1306 oled display 128x64 ? May 16, 2015 12:30PM |
Re: Repetier with SSD1306 oled display 128x64 ? May 16, 2015 02:24PM |
-=Delta G2K=-|
Re: Repetier with SSD1306 oled display 128x64 ? December 09, 2015 09:07AM |
Re: Repetier with SSD1306 oled display 128x64 ? December 09, 2015 09:46AM |
Re: Repetier with SSD1306 oled display 128x64 ? December 09, 2015 10:02AM |
Re: Repetier with SSD1306 oled display 128x64 ? December 09, 2015 10:16AM |
Re: Repetier with SSD1306 oled display 128x64 ? December 09, 2015 10:35AM |
Re: Repetier with SSD1306 oled display 128x64 ? December 09, 2015 12:18PM |
Re: Repetier with SSD1306 oled display 128x64 ? December 11, 2015 02:10AM |
Anonymous User
Re: Repetier with SSD1306 oled display 128x64 ? January 14, 2016 03:34PM |
Anonymous User
Re: Repetier with SSD1306 oled display 128x64 ? January 15, 2016 12:43AM |
Re: Repetier with SSD1306 oled display 128x64 ? January 16, 2016 12:07PM |
#ifdef U8GLIB_SSD1306_I2C
u8g_InitI2C(&u8g,&u8g_dev_ssd1306_128x64_i2c,U8G_I2C_OPT_NONE);
#endif
#ifdef U8GLIB_SSD1306_SW_SPI
u8g_InitSPI(&u8g,&u8g_dev_ssd1306_128x64_sw_spi, UI_DISPLAY_D4_PIN, UI_DISPLAY_ENABLE_PIN, UI_DISPLAY_RS_PIN, U8G_PIN_NONE, U8G_PIN_NONE);
#endif
Re: Repetier with SSD1306 oled display 128x64 ? July 19, 2017 10:34PM |
