Z Offset In Repertier Host ?
Posted by scubi
July 27, 2015 02:54PM
Hi Guys,
I use a a glass plate & and aluminum plate. The problem I have at the moment is that the aluminum plate is 1mm thicker than the glass.
Where can I change the Z offset in Repetier Host. Slic3r you can use the Z offset to to accommodate your change in plate.
Thanks
Re: Z Offset In Repertier Host ?
August 10, 2015 03:22AM
If you have max endstop you can simply change z length by the difference.
Next update (92.4) will contain a feature to compensate for bed coating with different thickness. But be aware that with zmin it will always go down to minimum z and then correct, so with big differences you really want z max endstop.
