Reason for: Printer reset detected - initalizing
Posted by 4Stroke
September 01, 2015 05:04AM
Hey everyone,
I am running Repetier 1.5.5 on Win8 with Repetier firmware 0.92 and a rumba board and I quite often get an error during print. The printer stops its movements completely for maybe one second and than continuous as nothing happened. This stop sometimes accurs after a couple of layers, sometimes after 2h and sometimes a complete 6h print is error free.
It seems the freeze is caused by a printer reset:
23:51:22.121 : ok 16582
23:51:22.123 : N16587 G1 X72.061 Y46.307 E6.0774 *121
23:51:22.124 : N16588 G1 X72.504 Y46.336 E6.08671 F900 *17
23:51:22.223 : ok 16583
23:51:22.227 : N16589 G1 X74.011 Y46.636 E6.11899 *77
23:51:22.326 : ok 16584
23:51:22.326 : N16590 G1 X75.466 Y47.13 E6.15127 *120
23:51:23.486 : Printer reset detected - initalizing
23:51:23.486 : start
23:51:23.487 : Info:External Reset
23:51:23.496 : Transformation matrix: 1.000000 0.000000 0.000000 0.000000 1.000000 0.000000 0.000000 0.000000 1.000000
23:51:23.498 : Free RAM:4428
23:51:23.581 : FlowMultiply:100
23:51:24.018 : N1 M110 *2
23:51:24.018 : N2 M115 *4
23:51:24.125 : N3 M105 *4
23:51:24.684 : N4 M111 S6 *67
23:51:24.685 : N5 T0 *31
23:51:24.685 : N6 M20 *55
10:49:01.974 : N3571 G1 X128.783 Y27.186 E121.9692 *121
10:49:02.474 : ok 3566
10:49:02.474 : N3572 M105 *52
10:49:02.474 : N3573 G1 X129.461 Y27.186 E121.9835 *118
10:49:02.505 : ok 3567
10:49:02.505 : N3574 G1 X145.393 Y11.254 E122.4567 *124
10:49:03.661 : Printer reset detected - initalizing
10:49:03.661 : start
10:49:03.661 : Info:External Reset
10:49:03.677 : Transformation matrix: 1.000000 0.000000 0.000000 0.000000 1.000000 0.000000 0.000000 0.000000 1.000000
10:49:03.677 : Free RAM:5191
10:49:03.771 : FlowMultiply:100
10:49:04.208 : N1 M110 *2
10:49:04.208 : N2 M115 *4
10:49:04.208 : ok
10:49:04.208 : ok 2
10:49:04.864 : FIRMWARE_NAME:Repetier_0.92.3 FIRMWARE_URL:[github.com] PROTOCOL_VERSION:1.0 MACHINE_TYPE:Core_XY EXTRUDER_COUNT:1 REPETIER_PROTOCOL:3
10:49:04.864 : N3 M111 S6 *68
10:49:04.864 : Printed filament:0.00m Printing time:0 days 0 hours 0 min
10:49:04.880 : N4 T0 *30
10:49:04.880 : N5 M20 *52
10:49:04.880 : N6 M220 S130 *68
10:49:04.880 : N7 M221 S100 *71
10:49:04.880 : N8 M111 S6 *79
10:49:04.880 : N9 T0 *19
10:49:04.880 : N10 M80 *10
10:49:04.880 : ok 3
What could probably cause Printer reset detected - initalizing? What should I look out for?
Edited 2 time(s). Last edit at 09/01/2015 05:08AM by 4Stroke.
Ein Schlosser ohne Hammer ist ein Jammer, ein Schlosser ohne Feile geht 'ne Weile
Re: Reason for: Printer reset detected - initalizing
September 01, 2015 09:35AM
I think that is the message you would get if you hit the reset button on the rumba board. Just try hitting hit after connection and you should get the same message.
Next would be finding why the reset signal gets triggered. Look out for possible shorts and other cables that could induct wrong signals. It just needs a little spike to trigger reset.
