Invalid Delta Coordinate - Move ignored Issue
Posted by Moesling
September 08, 2015 03:45AM
Hi Community,
I recently setup a Kossel XL Delta Printer and switched the first time to Repetier Firmware due to autoleveling Options.
The Kossel has mechanic endstop Switches, a heatbed, and FSR Sensors for Autoleveling. I use a Rumba Board with 32 Microsteps. Extruder is installed but not yet finetuned for steps per mm.
Nozzle is Z-Probe and it is connected and configured directly to Z-Min Pin.
My Printer seems to be missconfigured.
When I use G28 right after startup it homes perfectly.
When I try to G30 after homing it is coming down to approx 10mm above the Surface and gives an error message.
- Invalid Delta Coordinate (only Z-Axis) with a Value of -101180 (what does that mean)
- after that I Need to shutdown and restart... otherwise I got another Message popup --> RequestPause: Homing failed
I am really stuck and search Solutions for the last 4 Weeks. Found a lot of People talking about the same Issues but as soon as they got a solution they just do not feedback to the community.
Therefore I decided to "nerv" you all with the same (hopefully silly) Problems again.
Any help would be appreciated.
Cheers
Martin
open | download - Configuration.h (26.4 KB)
Re: Invalid Delta Coordinate - Move ignored Issue
September 08, 2015 09:03AM
Check your eeprom values. This normally happens when some values are set to nonsense values due to wrong eeprom initalization Happens if you had a different config on first upload.
September 08, 2015 01:37PM
Thanks for your reply.
Ok. So I used M502 to reset all settings to Firmware defaults.
In fact I need some more information.
When calibratet.... what procedure do I have to follow?
I stuck with a simple G30 and got failure messages (Invalid Delta Coordinate (only Z-Axis)). I rechecked all entries in the firmware and for me they seem ok.
Printer is well calibrated and the end-effector is almost everywhere at the same hight when moving around close to the surface.
That whole auto-bed-leveling thing is a bit frustrating right now. I never had a successful G29.
Did you probably took a look at my config.h? Is there something wrong?
I need to know where I have to start trouble-shooting.
Thanks for any advise.
Martin
September 08, 2015 01:58PM
You better once change EEPROM_MODE if you do not want top read your eeprom values.
Do didn't read config. Too time intensive with all the questions I get.
Once G30 works the rest will start working as well since it is just repeated usage of G30.
September 09, 2015 08:12AM
Hi Readers,
Finally I found a post of you wrote at the end of 2013 where you mentioned a Problem using large Diagonal Rods over 300mm. This thing is still not fixed. Firmware does no Floating or whatever for larger ways.
I decided to Switch to 16Microsteps changed steps per mm in config.h and Voila! it worked.
For all Delta Users out there this is a way to go.
Cheers
Martin
Hi Readers,
Cheers
Martin
Hi Readers,
Cheers
Martin
September 09, 2015 09:06AM
@Moesling: You only have to post a message once!
Bob Morrison
Wörth am Rhein, Germany
"Luke, use the source!"
BLOG - PHOTOS - Thingiverse
September 09, 2015 09:31AM
It should switch to float on AVR boards and to 64 bit int on arduino due based boards.
