Hi everybody!
I want to use
two steppers for my y-axis. My board - an extended Azteeg X3 - has capability to wire both y-steppers on a
different motor driver. So both drivers are working independently.
But how to map this in the firmware? I want to use repetier 0.91 for that.
Is it neccessary to modfify the source code for that or is it already build-in?
If not, where can I adjust that?
BTW: extended Azteeg X3: I have made an additional board to use the idle laying ports at the expansion board for two more stepper drivers, three mosfet-outputs an two more ports for incoming signals. If someone is interessted on that, I can post the layout here.
Regards
Stefan
Edited 1 time(s). Last edit at 09/12/2015 04:00AM by Reparator.
