Problem Repetier Host multi-extruder single HotEnd September 18, 2015 06:32PM |
Re: Problem Repetier Host multi-extruder single HotEnd September 21, 2015 03:09AM |
Re: Problem Repetier Host multi-extruder single HotEnd September 21, 2015 03:33AM |
Re: Problem Repetier Host multi-extruder single HotEnd September 21, 2015 05:28AM |
Re: Problem Repetier Host multi-extruder single HotEnd September 21, 2015 05:39AM |
Re: Problem Repetier Host multi-extruder single HotEnd September 27, 2015 09:31AM |
; Default start code M80 {IF_EXT0}M104 T0 S{TEMP0} {IF_EXT1}M104 T1 S{TEMP1} {IF_EXT2}M104 T2 S{TEMP2} {IF_EXT3}M104 T3 S{TEMP3} G28 ; Home G29 ; Autobed level G0 X0 Y0 Z5 F8000 ; Out plane {IF_BED}M190 S{BED} M107 ; Turn off fan G90 ; Absolute positioning M82 ; Extruder in absolute mode G92 E0 ; Reset extruder position ; Wait for all used extruders to reach temperature {IF_EXT0}M109 T0 S{TEMP0} {IF_EXT1}M109 T1 S{TEMP1} {IF_EXT2}M109 T2 S{TEMP2} {IF_EXT3}M109 T3 S{TEMP3}
;Generated with Cura_SteamEngine 15.01 ; Default start code M80 M104 T1 S210 M104 T2 S210 G28 ; Home G29 ; Autobed level G0 X0 Y0 Z5 F8000 ; Out plane M190 S50 M107 ; Turn off fan G90 ; Absolute positioning M82 ; Extruder in absolute mode G92 E0 ; Reset extruder position ; Wait for all used extruders to reach temperature M109 T1 S210 M109 T2 S210 ;Layer count: 200 ;LAYER:0 M107 G0 F9000 X55.613 Y60.518 Z0.300 ;TYPE SKIRT G1 F1800 X56.624 Y59.678 E0.06558
Re: Problem Repetier Host multi-extruder single HotEnd September 27, 2015 09:41AM |
