Good evening!
How can I advise
Repetier-Server to switch off the heated bed after a print? Is there any switch in configuration?
If I start a print on the server (I tested 0.60.4) everything works fine. After the print the extruder get switched off but not the heated bed. It stays at the last temperature, which is not acceptable for overnight or unattended prints.
Same behavior even if I add costum G-code at the end in Slic3r like this:
M140 S60 R20; Sollwert Heatbed wieder auf 60
M104 S205; Sollwert Extruder 1 wieder auf 205
M104 S0 ; turn off temperature
M140 S0; turn off heatbed
G28 X0 ; home X axis
M84 ; disable motors
M106 S0; Licht aus
Any ideas?
Regards
Stefan
