speed recognition
October 08, 2015 05:55AM
Hello Everyone.
Sorry for the n00by question, here it is:
I am confident in using slicing tools like slic3r. They give you the possibility to set velocities (i.e. velocity on the perimeters, on the infill ... [manual.slic3r.org] )
As a result, when I generate the G-Code, I have this kind of output:
[...previous lines...]
G1 Z147.200 F7800.000
G1 Z149.400 F7800.000
M107
M104 S0 ; turn off temperature
G28 X0 ; home X axis
M84 ; disable motors
; avoid_crossing_perimeters = 1
; bed_size = 200,200
; bed_temperature = 0
[cut]
; first_layer_speed = 10
; first_layer_temperature = 205
[cut]
; bridge_speed = 40
; external_perimeter_speed = 30
; infill_speed = 40
[etc]
The question is:
How this firmware extract the "speed" information when needed ?
I expected some firmware instructions (like M220: Set speed factor override percentage) in the G-CODE when passing i.e. from infill to perimeters... but this is not true !
so how the firmware "decides" when we are on a perimeter or in a infill and how does it set corresponding velocities ?
Similar consideration can be done for accelerations.
[this is because I am writing a custom firmware]
Thanks a lot,
Paolo
Edited 2 time(s). Last edit at 10/08/2015 07:12AM by emdcp.
Re: speed recognition
October 08, 2015 09:53AM
Ah ok, I answer to myself:
That info is contained in F parameters of the G0/G1 instructions (also if the terminology "feedrate" can be disguising confused smiley [reprap.org] )
This generates new questions in me, but this is matter for another section of these forums.
cya
