TTN
How to turn on fan when stepper drivers turn on?
November 15, 2015 08:04PM
Is there a PWM solution that can turn on the fan when the stepper drivers power up?
To provide some cooling, I'd like to put a small fan near the board to get some air circulating, it only needs to run when the stepper drivers are on.
PWM would be very hand in this case, then I can set it to 50% or so, whereas now if I hook up the fan it will be on full speed all the time which is noisy.
I'm using an solid state relay for the heatbed which runs off a spare arduino pin, freeing up one of the ramps1.4 mosfets for the extra fan.
TTN
Re: How to turn on fan when stepper drivers turn on?
November 15, 2015 08:06PM
I did lots of googling and I searched this subforum but I didn't find what I was looking for.
November 16, 2015 03:25AM
There is a board fan pin that does exactly that. It assumes only when printing we need cooling so it turns fan off when motors are off.
TTN
November 16, 2015 07:33AM
Thanks!
Though I can't seem to find the setting in configuration.h
Is it in configuration.h or where should I look?
For future googlers who come looking here this may also be of interest/use to you:
[github.com]
[captain-slow.dk]
Edited 1 time(s). Last edit at 11/16/2015 07:44AM by TTN.
November 16, 2015 08:30AM
#define FAN_BOARD_PIN yourpinnumber
should do. In config tool it is in features section.
TTN
November 16, 2015 04:33PM
I can't find it in configuration.h (got it from github) I'll just define it in configuration.h and that should do the trick. smiling smiley
Thanks!
EDIT: worked smiling smiley
Edited 2 time(s). Last edit at 11/16/2015 05:55PM by TTN.
TTN
November 16, 2015 06:58PM
Is it possible to set a PWM value for the FAN_BOARD_PIN?
