Improvement suggestion:
Change:
#define DELTA_X_ENDSTOP_OFFSET_STEPS 0
#define DELTA_Y_ENDSTOP_OFFSET_STEPS 0
#define DELTA_Z_ENDSTOP_OFFSET_STEPS 0
to:
#define DELTA_X_ENDSTOP_OFFSET_STEPS 0.0*AXIS_STEPS_PER_MM
#define DELTA_Y_ENDSTOP_OFFSET_STEPS 0.0*AXIS_STEPS_PER_MM
#define DELTA_Z_ENDSTOP_OFFSET_STEPS 0.0*AXIS_STEPS_PER_MM
unless, of course, floats are an issue.
I'm not too familiar with the C syntax, but I'm assuming we will have to convert the number to an int before using it later in the code.
I can go ahead and open a git pull request, but thought it better to discuss first.
Edited 1 time(s). Last edit at 12/03/2015 09:29PM by TTN.
