Repetier Host V1.6.1, Error: Line Number is not Last Line Number +1
Posted by SCro3D
February 14, 2016 08:05PM
Any help on this would be greatly appreciated.
My hotend was working just fine when I needed to replace HotEnd Barrel. I powered everything down and changed it. I started Repetier back up it asked to update to V1.6.1. I did so then all these errors started and has made the printer INOP.
First I will get the error :Extruder switched off. MINTEMP triggered ! I assumed I had errors with my extruder thermistor. I checked the voltage at T0, it is 4.9V. The thermistor checked out OK as well. To check it even further, I hooked T1 and was able to manipulate the temperature using body heat (Breathed on it) and watched the temperature go up, so I know the thermistor is good.
I scrolled down in the log and noticed “Error: Line Number is not Last Line Number+1, Last Line:14. The last line changes each time I restart it.
I am using Marlin 1.1.0 RC2 with no issues for the last 2 months.
I changed the hotend thermistor 2 weeks ago and have worked fine as well till today. Is it common, or has anyone heard of T0 on the board going bad? Could it be Marlin? Would it be that big a difference from RC2 to RC3 with V1.6.1? I am at a loss, so anything I can get would be great.
My error log is below:
19:23:47.031 : OpenGL version:3.1.0 - Build 9.17.10.4229
19:23:47.031 : OpenGL extensions:GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_blend_color GL_EXT_abgr GL_EXT_texture3D GL_EXT_clip_volume_hint GL_EXT_compiled_vertex_array GL_SGIS_texture_edge_clamp GL_SGIS_generate_mipmap GL_EXT_draw_range_elements GL_SGIS_texture_lod GL_EXT_rescale_normal GL_EXT_packed_pixels GL_EXT_texture_edge_clamp GL_EXT_separate_specular_color GL_ARB_multitexture GL_EXT_texture_env_combine GL_EXT_bgra GL_EXT_blend_func_separate GL_EXT_secondary_color GL_EXT_fog_coord GL_EXT_texture_env_add GL_ARB_texture_cube_map GL_ARB_transpose_matrix GL_ARB_texture_env_add GL_IBM_texture_mirrored_repeat GL_EXT_multi_draw_arrays GL_NV_blend_square GL_ARB_texture_compression GL_3DFX_texture_compression_FXT1 GL_EXT_texture_filter_anisotropic GL_ARB_texture_border_clamp GL_ARB_point_parameters GL_ARB_texture_env_combine GL_ARB_texture_env_dot3 GL_ARB_texture_env_crossbar GL_EXT_texture_compression_s3tc GL_ARB_shadow GL_ARB_window_pos GL_EXT_shadow_funcs GL_EXT_stencil_wrap GL_ARB_vertex_program GL_EXT_texture_rectangle GL_ARB_fragment_program GL_EXT_stencil_two_side GL_ATI_separate_stencil GL_ARB_vertex_buffer_object GL_EXT_texture_lod_bias GL_ARB_occlusion_query GL_ARB_fragment_shader GL_ARB_shader_objects GL_ARB_shading_language_100 GL_ARB_texture_non_power_of_two GL_ARB_vertex_shader GL_NV_texgen_reflection GL_ARB_point_sprite GL_ARB_fragment_program_shadow GL_EXT_blend_equation_separate GL_ARB_depth_texture GL_ARB_texture_rectangle GL_ARB_draw_buffers GL_ARB_color_buffer_float GL_ARB_half_float_pixel GL_ARB_texture_float GL_ARB_pixel_buffer_object GL_EXT_framebuffer_object GL_ARB_draw_instanced GL_ARB_half_float_vertex GL_ARB_occlusion_query2 GL_EXT_draw_buffers2 GL_WIN_swap_hint GL_EXT_texture_sRGB GL_ARB_multisample GL_EXT_packed_float GL_EXT_texture_shared_exponent GL_ARB_texture_rg GL_ARB_texture_compression_rgtc GL_NV_conditional_render GL_EXT_texture_swizzle GL_ARB_sync GL_ARB_framebuffer_sRGB GL_EXT_packed_depth_stencil GL_ARB_depth_buffer_float GL_EXT_transform_feedback GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_ARB_framebuffer_object GL_EXT_texture_array GL_EXT_texture_integer GL_ARB_map_buffer_range GL_EXT_texture_snorm GL_INTEL_performance_queries GL_ARB_copy_buffer GL_ARB_sampler_objects GL_NV_primitive_restart GL_ARB_seamless_cube_map GL_ARB_uniform_buffer_object GL_ARB_depth_clamp GL_ARB_vertex_array_bgra GL_ARB_shader_bit_encoding GL_ARB_draw_buffers_blend GL_ARB_texture_query_lod GL_ARB_explicit_attrib_location GL_ARB_draw_elements_base_vertex GL_ARB_instanced_arrays GL_ARB_fragment_coord_conventions GL_EXT_gpu_program_parameters GL_ARB_texture_buffer_object_rgb32 GL_ARB_compatibility GL_ARB_texture_rgb10_a2ui GL_ARB_vertex_type_2_10_10_10_rev GL_ARB_timer_query GL_INTEL_map_texture GL_ARB_vertex_array_object GL_ARB_provoking_vertex
19:23:47.031 : OpenGL renderer:Intel(R) HD Graphics 3000
19:23:47.031 : Using fast VBOs for rendering is possible
19:23:55.098 : Printer reset detected - initalizing
19:23:55.098 : start
19:23:55.098 : echo:Marlin1.0.2
19:23:55.113 : echo: Last Updated: Feb 14 2016 15:01:37 | Author: (none, default config)
19:23:55.113 : Compiled: Feb 14 2016
19:23:55.113 : echo: Free Memory: 3766 PlannerBufferBytes: 1232
19:23:55.113 : echo:Hardcoded Default Settings Loaded
19:23:55.113 : echoconfused smileyteps per unit:
19:23:55.113 : echo: M92 X158.67 Y76.36 Z2969.50 E190.07
19:23:55.113 : echo:Maximum feedrates (mm/s):
19:23:55.113 : echo: M203 X500.00 Y500.00 Z5.00 E25.00
19:23:55.113 : echo:Maximum Acceleration (mm/s2):
19:23:55.113 : echo: M201 X700 Y700 Z1000 E10000
19:23:55.113 : echo:Acceleration: S=acceleration, T=retract acceleration
19:23:55.113 : echo: M204 S700.00 T3000.00
19:23:55.129 : echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s)
19:23:55.129 : echo: M205 S0.00 T0.00 B20000 X8.00 Z0.40 E5.00
19:23:55.129 : echo:Home offset (mm):
19:23:55.129 : echo: M206 X0.00 Y0.00 Z0.00
19:23:55.129 : echotongue sticking out smileyID settings:
19:23:55.129 : echo: M301 P14.65 I0.59 D90.59
19:23:58.592 : echoconfused smileyD init fail
19:23:58.623 : FIRMWARE_NAME:Marlin V1.0.2; Sprinter/grbl mashup for gen6 FIRMWARE_URL:[github.com] PROTOCOL_VERSION:1.0 MACHINE_TYPE:Mendel EXTRUDER_COUNT:1 UUID:00000000-0000-0000-0000-000000000000
19:23:58.686 : X:0.00 Y:0.00 Z:0.00 E:0.00 Count X: 0.00 Y:0.00 Z:0.00
19:23:58.686 : echo:Active Extruder: 0
19:23:58.686 : Begin file list
19:23:58.686 : End file list
19:23:58.733 : Error:0
19:23:58.733 : : Extruder switched off. MINTEMP triggered !
19:23:58.764 : Errortongue sticking out smileyrinter stopped due to errors. Fix the error and use M999 to restart. (Temperature is reset. Set it after restarting)
19:24:32.727 : Resend: 15
19:24:32.758 : Error:Line Number is not Last Line Number+1, Last Line: 14
19:24:32.758 : Resend: 15
19:24:32.821 : Error:0
19:24:32.821 : : Extruder switched off. MINTEMP triggered !
19:24:32.821 : Errortongue sticking out smileyrinter stopped due to errors. Fix the error and use M999 to restart. (Temperature is reset. Set it after restarting)
19:24:41.307 : Error:Line Number is not Last Line Number+1, Last Line: 14
19:24:41.307 : Resend: 15
19:24:44.333 : Error:Line Number is not Last Line Number+1, Last Line: 14
19:24:44.333 : Resend: 15
19:24:47.391 : Error:Line Number is not Last Line Number+1, Last Line: 14
19:24:47.391 : Resend: 15
19:24:50.464 : Error:Line Number is not Last Line Number+1, Last Line: 14
19:24:50.464 : Resend: 15
19:24:53.522 : Error:Line Number is not Last Line Number+1, Last Line: 14
19:24:53.522 : Resend: 15
19:24:56.566 : Error:Line Number is not Last Line Number+1, Last Line: 14
19:24:56.566 : Resend: 15
19:24:59.639 : Error:Line Number is not Last Line Number+1, Last Line: 14
19:24:59.639 : Resend: 15
19:25:02.681 : Error:Line Number is not Last Line Number+1, Last Line: 14
19:25:02.681 : Resend: 15
19:25:05.754 : Error:Line Number is not Last Line Number+1, Last Line: 14
19:25:05.754 : Resend: 15
19:25:08.812 : Error:Line Number is not Last Line Number+1, Last Line: 14
19:25:08.812 : Resend: 15
19:25:11.870 : Error:Line Number is not Last Line Number+1, Last Line: 14
19:25:11.870 : Resend: 15
19:25:14.927 : Error:Line Number is not Last Line Number+1, Last Line: 14
19:25:14.927 : Resend: 15
19:25:17.985 : Error:Line Number is not Last Line Number+1, Last Line: 14
19:25:17.985 : Resend: 15
19:25:21.042 : Error:Line Number is not Last Line Number+1, Last Line: 14
19:25:21.042 : Resend: 15
19:25:24.102 : Error:Line Number is not Last Line Number+1, Last Line: 14
19:25:24.102 : Resend: 15
Re: Repetier Host V1.6.1, Error: Line Number is not Last Line Number +1
February 15, 2016 05:40PM
Looks like it is not Repetier.
I have changed the Thermistor, RAMPS 1.4, Arduino 2650 and used Pronterface. Still get the Extruder MinTemp. Something is not right in Marlin then, Oh Well.
February 20, 2016 11:43AM
You need to fix this Marlin error
some thermistors are not connected or configured wrong.
