problem with axis movments
Posted by melvinbrucepaton
April 26, 2016 10:05AM
Hello All
i am having a problem with the manual movement of the axis in the soft ware repetier,
I move y axis forward with the manual controls, then when i try move it back wards with the manual controls the z axis moves,
i am using a arduino mega 2560 with a ramps 1.4 which are driving DQ542ma"s which run the nema 23 motors.
even if i send g codes they behave the same .
G0 Y100
G28
these are the codes i used.
thanks
Melvin
Re: problem with axis movments
April 27, 2016 01:11AM
Problem resolved, turns out i needed to add the enable wire from the ramps 1.4 to the DQ542ma"s aswell as enable the the enable xyz in config h.
