Repetier Server suddenly stopped working (due to auto update) April 30, 2016 07:36AM |
pi@raspberrypi ~ $ sudo /etc/init.d/RepetierServer start [ ok ] Starting Repetier-Server: rsd.
pi@raspberrypi ~ $ /usr/local/Repetier-Server/bin/RepetierServer --config=/usr/local/Repetier-Server/etc/RepetierServer.xml Read configuration file /usr/local/Repetier-Server/etc/RepetierServer.xml Testing alternative config: "/usr/local/Repetier-Server/etc/RepetierServer-extra.xml" Testing alternative config: "/var/lib/Repetier-Server/database/RepetierServer.xml" Webdirectory: /usr/local/Repetier-Server/www/ Storage directory: /var/lib/Repetier-Server/ Configuration file: /usr/local/Repetier-Server/etc/RepetierServer.xml Directory for temporary files: /tmp/ Reading firmware data ... Starting Network ... Reading printer configurations ... Reading printer config /var/lib/Repetier-Server/configs/Prusa_i3.xml Starting printer threads ... Starting work dispatcher subsystem ... Starting user database ... Initalizing LUA ... Starting web server ... Webserver started. Error parsing version string <!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">: Syntax error terminate called after throwing an instance of 'Poco :: SyntaxException' what(): Syntax error Abgebrochen
pi@raspberrypi ~ $ sudo route delete default
pi@raspberrypi ~ $ /usr/local/Repetier-Server/bin/RepetierServer --config=/usr/local/Repetier-Server/etc/RepetierServer.xml Read configuration file /usr/local/Repetier-Server/etc/RepetierServer.xml Testing alternative config: "/usr/local/Repetier-Server/etc/RepetierServer-extra.xml" Testing alternative config: "/var/lib/Repetier-Server/database/RepetierServer.xml" Webdirectory: /usr/local/Repetier-Server/www/ Storage directory: /var/lib/Repetier-Server/ Configuration file: /usr/local/Repetier-Server/etc/RepetierServer.xml Directory for temporary files: /tmp/ Reading firmware data ... Starting Network ... Reading printer configurations ... Reading printer config /var/lib/Repetier-Server/configs/Prusa_i3.xml Starting printer threads ... Starting work dispatcher subsystem ... Starting user database ... Initalizing LUA ... Starting web server ... Webserver started. Net Exception: Network is unreachable Net Exception: Network is unreachable Connection started: Prusa i3 Reset printer Prusa i3 Net Exception: Network is unreachable Net Exception: Network is unreachable
Re: Repetier Server suddenly stopped working (due to auto update) December 16, 2017 07:30AM |
pi@raspberrypi ~/Repetier-Server/logs $ tail /var/lib/Repetier-Server/logs/server.log 2017-12-16 12:23:36: Start logging... 2017-12-16 12:23:36: Webdirectory: /usr/local/Repetier-Server/www/ 2017-12-16 12:23:36: Storage directory: /var/lib/Repetier-Server/ 2017-12-16 12:23:36: Configuration file: /usr/local/Repetier-Server/etc/RepetierServer.xml 2017-12-16 12:23:36: Directory for temporary files: /tmp/ 2017-12-16 12:23:36: Reading firmware data ... 2017-12-16 12:23:37: Starting Network ... 2017-12-16 12:23:37: Reading printer configurations ... 2017-12-16 12:23:37: Reading printer config /var/lib/Repetier-Server/configs/Prusa_i3.xml 2017-12-16 12:23:37: Error parsing version string : Syntax error pi@raspberrypi ~/Repetier-Server/logs $
