Repetier and the Z axis
Posted by Templar66
May 12, 2016 09:57PM
Hi
I have posted in another area about this but thought it may be more suitable here.
I have just been setting up my 3d stuffmaker mega prusa i3 and the problem I have is I have calibrated it so when I send the axis to home the extruder moves back to the far right corner and sits a fraction of a mm off the bed as it should.
When I try to print, the z axis wants go deeper and hits the bed and I have to kill the print.
I can only assume its the software that is doing this, and others have suggested its the offsets in slic3r doing it.
The main problem is I have no idea where to look for the offsets and how to change them.
If any one can help, I would greatly appreciate it.
Regards
Ian
Re: Repetier and the Z axis
June 01, 2016 10:23PM
You can see what z offset slic3r is using in the slic3r configuration.
Alternatively, it could be in the repetier firmware depending what you have for Z_PROBE_Z_OFFSET, as I noticed this appears to make the Z axis move down for a given length after the Z endstop is triggered.
Edited 1 time(s). Last edit at 06/01/2016 10:26PM by PDBeal.
June 01, 2016 10:47PM
Hi
Sorry, we worked this problem out. It was definitely the z offset you have defined here. I had to change mine to 3.8 to get it to work right.
Since then I have had to swap to cura due to other printing issues, and the problem hasn't been there.
Regards
Ian
