I want to insert a Gcode to pause the print, so I can change filament.
I want the extruder to stay heated, as well as the bed.
Maybe home the X, to avoid droop on the object....
My Machine runs on RAMPS on Arduino, with Repetier firmware and Repetier Host a controller
In the reprapwiki on Gcode, I find M226
However, it states repetier not supported.
Should I do something else ?
Thomas
www.3daybreaker.blogspot.com
Orca V4.4 rebuild to Ramps with Mk8 and E3D, as well as a Rostock Delta Mini and an OLO in backorder :-)
